4R100 hesitation..? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-17-2015, 01:36 AM Thread Starter
bigblak250's Avatar
4R100 hesitation..?
i have a 2000 7.3 2wd 4R100, when i fire it up and put it in drive it acts like its in neutral for a few seconds until i rev it just a little bit, only does it right off of start up after that you can drive it all day and its good, im thinking maybe the seal on the filter is bad and fluid is leaking down as it sits then takes a little to prime back up? anyone else had this problem or know how to fix it? thanks in advance
00, f-250, 7.3 auto 4x4,35 toyos on 20's, 07 HD lights grill and bumper, AIH delete, ebpv delete, banks intercooler, banks turbine housing, high flow outlet, banks actuator, wildman 6 pos, wicked wheel, 6637 filter intake, 5in exhaust, hpo cross over line, dieselsite brv, and hutch mods
bigblak250 is offline
post #2 of 2 (permalink) Old 03-25-2015, 04:23 PM
matthewd11's Avatar
Re: 4R100 hesitation..?
Could be worn seals in transmission or a sticky valve in the valve body.
matthewd11 is offline
