96 e40d swap with 4r100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-14-2015, 08:17 PM Thread Starter
I know itbis possible to swap a e40d with a 4r100 what parts do i need to make this possible
7.3 stroked out is offline
post #2 of 5 (permalink) Old 03-15-2015, 03:35 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 96 e40d swap with 4r100
You can put a 4R100 where an E4OD used to be, but you can't put an E4OD where a 4R100 lived.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 03-16-2015, 01:14 AM
ok so this just acknowledges the op's statement but what about answering his question, I to would like to know.
djs96 is offline
post #4 of 5 (permalink) Old 03-16-2015, 02:04 AM
kanuck15's Avatar
To the best of my recollection it's just a solenoid pack swap to adapt for the plug change. You won't use the output speed sensor so it can just sit there. Beyond that the physical trans is the same. Use your range sensor.
Or........ Get a 5 speed pcm along with the pcs stand alone controller for the trans
Trucks and parts............
kanuck15 is offline
post #5 of 5 (permalink) Old 09-25-2015, 04:58 AM
Justaworktruck
John Martens's Avatar
Did this ever get done, just getting a 4r100 done up, what changes actually need to happen.
Shift linkage, which solenoid pack? TR sensor.
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
