cracked flexplate - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 09-28-2009, 12:51 PM Thread Starter
cracked flexplate
Hi All; I'm new to thisforum. I recently purchased a 99 F350 dually w/121,000 miles for $9500. It's a black SC & is so clean there isn't even a swirl mark in the paint. It was pretty noisy when I first picked it up, so I changed the oil to Royal Purple synthetic & added Power Service to the fuel. It has quieted down a lot but the dealer told Me that when they flushed the trans they found the flexplate is cracked. I took it elsewhere for a second opinion(don't really trust dealers) & was told this is a common occurence with the 7.3 diesels. I bought this truck to tow a 5th wheel when I retire in a few years, & I would like someone to tell Me if I need to go with an aftermarket replacment or will the original hold up ok. The truck has a 4" turbo back with a muffler, and was told by the dealer it also has a performance chip(no idea which one). I'm not a hotrodder anymore but I love the shove in the back when you step on it. Any help would be appreciated.
thanks AL
2yamahas is offline
post #2 of 8 (permalink) Old 09-28-2009, 06:04 PM
oilfield trash
big adam's Avatar
Re: cracked flexplate
when mine cracked, i decided to drop the coin, and got the ats flexplate. that is the way i would do it again.
97 F350 cc lb 2wd 4" diy exhaust, diy intake, bully dog 6pos, ranch hand front and back
big adam is offline
post #3 of 8 (permalink) Old 09-28-2009, 07:55 PM
kampinguru's Avatar
What is the flexplate?
2000 F250 Lariat S/C SB 4X4 Off-Road
7.3L PSD
2005 Cedar Creek 30RLBS
PullRite Superglide Hitch
Firestone Ride-Rite Airbags and Dual Commander II
ATS turbo housing
AFE Stage 2 intake with PG7 filter and sock.
DP Tuner 40tow, 80 econ, 100 Race
BTS transmission April 09
Magnaflow 4" turbo back exhaust
kampinguru is offline
post #4 of 8 (permalink) Old 09-28-2009, 08:13 PM
sick97psd1's Avatar
Send a message via AIM to sick97psd1
It isn't supper common, I recently bought a truck with a cracked flexplate at the vehicle auction here for $1500 cause they thought it had a rod knock! I am replacing it with a aftermarket stock replacement from the local transmission shop. It was only $80.
sick97psd1 is offline
post #5 of 8 (permalink) Old 09-29-2009, 12:47 PM Thread Starter
The flexplate is the piece that bolts to the rear of the engine crankshaft, then the torque convertor for the automatic transmission is bolted to the flex plate. The starter spins the flexplate via a ring gear welded to the plate.
Hope this helps
AL
2yamahas is offline
post #6 of 8 (permalink) Old 09-29-2009, 01:07 PM
PSN Mega Miler
crowz's Avatar
Otherwise known as a flywheel
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #7 of 8 (permalink) Old 09-29-2009, 04:08 PM
kampinguru's Avatar
Aaah. Flywheel/flexplate. Never heard it refered to as a flexplate before, but I am familiar with the term flywheel. Thanks very much.
7.3L PSD
ATS turbo housing
post #8 of 8 (permalink) Old 09-29-2009, 04:23 PM
PSN Mega Miler
crowz's Avatar
Always called them flywheel's too
crowz is offline
