In search of used E4OD specialty tools - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-14-2015, 03:07 AM Thread Starter
I'm just about to tear into my E4OD to figure out why my forward clutch is slipping so badly. I've already done all the electrical and electronic checks that can be done to these transmissions as per the ATSG manual, even though I had no flashing OD light or stored DTC's. Coming to the conclusion that I have a mechanical/hydraulic issue with the forward clutch assembly, I've decided to open this transmission up and see what's wrong. Specifically, I'm looking for these tools:
1. Clutch Spring Compressor Set (T88C-77000-AH-2 compressor bar), (T89T-70010-C spring fixture), (T89T-70010-F compressor plate).
2. Clutch Remover/Installer (T89T-70010-E)
3. Clutch Spring Compressor (T65L-77515-A)
4. Banding Tool (D89L-77000-?)
I'm not certain if these are OTC or Rotunda part numbers. I do know, however, that all these tools can be bought online, but I wanted to see if anybody on here had any or all of these tools that they'd be willing to part with, or rent out for a month or so. I've never been into an E4OD any deeper than the valve body, but I'm also no stranger to hydraulically operated transmissions. I've had my hands into a number of John Deere and J. I. Case Power Shift transmissions and control bodies, all of which are back in the field working flawlessly. I may be young, but I ain't no idiot! ;-)
1997 F-250 SCFB, 4X4, E4OD 341,000 all stock miles.
RustyBolts is offline
post #2 of 3 (permalink) Old 05-23-2015, 12:49 PM Thread Starter
Re: In search of used E4OD specialty tools
Bump to the top
post #3 of 3 (permalink) Old 05-30-2015, 12:42 AM
matthewd11's Avatar
You should only need a spring compressor. You can fab a way to install them into the case without special tool.
I have a clutch spring compressor that should work that i'd be willing to rent out. I use them on 4R100s and 5R110s i dont see why it wouldnt work on a E4OD as its basically the same as a 4R. PM me for more info.
matthewd11 is offline
