NV4500 possible? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-25-2009, 06:18 PM Thread Starter
NV4500 possible?
I have a truck with an E4OD at the moment. I also have a truck with a 6.9L and a T-19. I'm planning on putting the e4OD in the wife's bronco with the 6.9, which leaves the 7.3L powerstroke with either the T19 with no overdrive or me to come up with something to put in. I know the common wisdom is look around and find a ZF5 from a diesel to put in. However, what about the NV4500 from a dodge diesel using an adapter plate and the stock T19 bellhousing from the 6.9?
That would avoid the clutch master/slave issues a lot of guys experience.
Thoughts?
86turbodsl is offline
post #2 of 3 (permalink) Old 09-27-2009, 03:11 AM
What else?
smokyred's Avatar
Re: NV4500 possible?
What would you do for a clutch/flywheel?
Dave
smokyred is offline
post #3 of 3 (permalink) Old 10-15-2009, 12:52 AM Thread Starter
I'd do either the 99+ single mass fw i have or get a sbc smf for a psd -97
