Has anyone heard of this Mod\Change - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-03-2015, 10:28 AM Thread Starter
mx185sw's Avatar
Just Read online about someone changeing ther Trans pan and filter on the 2003-2007 SD 5R110 with the Pan and Filter from a 2008 SD...they mention the filter is a diff style, full flow pleated design vs screen design on the 03-07. Didnt know if anyone has done this and is it legit? Is there a diff and is it better?
thoughts?
Sean
___________________________________________
2005 F250 Harley CC SB Banks IQ, 4" Exhaust, Banks Techi Cooler with High Ram, Cold Air Intake, Cat Delete,EGR Delete,Coolant Filter,Amsoil Oil Filter Bypass, PHP ECM Rollback, PHP FICM Tuner, WW2,Rancho 9000XL shocks. Firestone Air Springs w/Daystar Cradles. 224K
mx185sw is offline
post #2 of 4 (permalink) Old 03-03-2015, 02:49 PM
matthewd11's Avatar
Re: Has anyone heard of this Mod\Change
If you have the inline filter on the passenger side by the radiator, the filter in the pan is only a screen that protects from large failures. the filter by the radiator is a fine micron count. If you have this style just leave it.
matthewd11 is offline
post #3 of 4 (permalink) Old 03-03-2015, 11:47 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Yes, I've heard of it. In my opinion it's a good change.
The newer internal filter is at least as good as the bypass filter on the older transmissions. the newer filter filters 100% of the flow, while the bypass filters between 1% and 10% of what's going through the converter, which is not all of the flow.
Mark
Mark Kovalsky is offline
post #4 of 4 (permalink) Old 03-04-2015, 02:47 PM Thread Starter
mx185sw's Avatar
Thank you for the followup... gonna do it when done with this next trip.. no time to do it before.
Sean
mx185sw is offline
