e4od problems issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-24-2015, 12:19 AM Thread Starter
Trans starting acting funny. Oh where to start. Once in a blue moon cluster will blank out and come right on. So cluster might have a glitch. This morning didn't want to shift into 3rd or lockup but if shift manually it will go in gear but sometimes pop out might go back in gear then pop out again. Then finally OD light started blinking. Here's the codes I got p0713, p0344, p1728, p0113. Then cleared the codes. Drove it did the same thing in no time then OD light again codes p0113 and p0603. Just looking for an idea where to start looking for problem. Could it be the pcm since I got the p0603 code and I did not unhook batteries.
mwbuilds is offline
post #2 of 5 (permalink) Old 02-24-2015, 11:26 AM Thread Starter
Re: e4od problems issues
Forgot to add. Trans fluid changed 2k ago and remote filter added. Fluid level ok. BTS valve body. 5" exhaust, intake and superchips tuner. Put back to stock no change.
mwbuilds is offline
post #3 of 5 (permalink) Old 02-24-2015, 02:29 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
With the cluster blanking out the trans computer is probably losing the vehicle speed signal that the cluster provides. That will cause the P1728 code and various shifting problems. Get that taken care of and the trans might be fine.
Mark
Mark Kovalsky is offline
post #4 of 5 (permalink) Old 02-24-2015, 03:23 PM Thread Starter
Is there a way to repair cluster without swapping it out. the cluster did not blink out once while this was going on.
mwbuilds is offline
post #5 of 5 (permalink) Old 02-26-2015, 09:33 PM Thread Starter
Not picking up different cluster till the weekend but pulled vss and cleaned, checked wiring and re greased. Did the same to mlps and solenoid pack connector. Nothing seemed broken. Took it for a drive seems to not half shift in 3rd and doesn't seem to lockup. Smash the pedal and rpms go up
mwbuilds is offline
