Trans not wanting to a hold a gear - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-21-2009, 11:10 PM Thread Starter
When towing the trans is shifting up a gear really early and lugging like it is wanting to find a gear in between. I was thinking the TC might need to be upgraded. What are your guys thoughts on what to do? If I was to rebuild the trans to get me by for a while what all would you recommend I get TC, Valve body? The truck is a 2000 7.3L auto with 130K. Thanks
bigwheel is offline
post #2 of 7 (permalink) Old 09-22-2009, 09:54 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Trans not wanting to a hold a gear
I don't understand how the torque converter, or turbocharger, or transfer case, or whatever else TC might be could affect this.
What you need is a different computer program. All the shifting happens when the computer tells it to happen. No hardware change is going to help with this.
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 09-22-2009, 11:00 PM Thread Starter
I never thought about the computer. Could I get that fixed by getting a chip with some trans tunes? When I am towing and get on throttle from a stop the truck will take off fine up until about 2200 rpm's. Then the trans up shifts and lose all momentum. This has been going on for about 8 months.
bigwheel is offline
post #4 of 7 (permalink) Old 09-23-2009, 01:04 PM
Have you checked codes..did you change something 8 months ago?
email:
Website:
OBSWIZ is offline
post #5 of 7 (permalink) Old 09-26-2009, 12:57 PM Thread Starter
There are no code that I have found so far. The stock turbo went out so I installed a van turbo about 6 months ago. And I thought about this.
bigwheel is offline
post #6 of 7 (permalink) Old 09-27-2009, 11:59 AM
Does your speedo work correctly? Is it accurate? If not, that could be causing the trans to shift at the wrong time.
If the speedo is working correctly then a chip with trans tunes is the only way to fix this.
post #7 of 7 (permalink) Old 09-27-2009, 01:54 PM Thread Starter
Awesome thanks for the help. If I get a chip setup for towing and econ will the trans hold up for a while or is there something that I could look at doing to it now?
bigwheel is offline
