e4od to zf5: Read Post #1 Before Posting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 09-21-2009, 08:03 PM Thread Starter
I know this is a semi-redundant thread but i'm hoping to put a new spin on this topic.
I would like to hear from those who have actually performed a zf5 or zf6 transmission swap on their rigs and no one else. I've read plenty of threads with people bickering back and forth about auto vs manual, but now I would like to know form those who have done it:
1) Was it worth the time/ money
2) Would you do it again given the chance
3) How long did it take
4) Do you like the zf5/zf6 over the automatic or do you wish you'd left the auto
I'm hoping to get some real tech from people that have done it and not a bunch of "well I would do this or that". Thanks guys!
Bran
95crew is offline
post #2 of 14 (permalink) Old 09-21-2009, 09:35 PM
The Original
BigStroker's Avatar
Re: e4od to zf5: Read Post #1 Before Posting
yea I broke the rules....
If your going to do a swap do the ZF5 over the 6spd easier to swap
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #3 of 14 (permalink) Old 09-22-2009, 09:05 AM
urbanwheeler's Avatar
if you have all the parts there to swap in, it shouldnt take more than a day to do the swap. when i did mine i had to wait on drivelines. it was well worth the money at the time, i broke my auto and it cost me less than rebuilding it. for towing in the hills i really like the 5sp but i now wish i had the auto back, now that i am getting to the point of not being able to have a completely street friendly clutch.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #4 of 14 (permalink) Old 09-22-2009, 12:09 PM
The Fireman
big_stroker's Avatar
I'm just wondering to why they ZF5 is easier than the ZF6.
Is there a size difference? One longer then the other or what? I'm not to familiar with the ZF5
I did the auto to ZF6 swap on my SD and I love it. I know my brother would love to do it to his OBS so who ever does it take some pics and post up. I would like to know some info on it.
big_stroker is offline
post #5 of 14 (permalink) Old 09-22-2009, 03:48 PM
The Original
BigStroker's Avatar
If memory serves right ZF6 is taller and shorter than the ZF5
#27
post #6 of 14 (permalink) Old 09-22-2009, 04:26 PM
Cowboy Up
It is taller and shorter, so you have to either do a body lift or massage (bfh) the transmission tunnel to make it work. Will the transfer case from the ZF5 work with the ZF6.
'96 F350 CCLB, Dually, 4wd, ZF6, 4.10's, 4" lift, Energy suspension and body bushings, Firestone airbags, 245/70R19.5, 3" DP, 4" MBRP straight pipe, Afe stage 2, TW 6 pos, Autometer gauges, Valair kevlar/ceramic clutch, Stage 1's, Shimmed FPR, Gutted EBPV, Welded pedestal, CCV mod, SD 7.3 intercooler, D66 Turbo, 17* HPOP
INTPSTROKE96 is offline
post #7 of 14 (permalink) Old 09-22-2009, 05:05 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
There is no way a 6 speed is shorter(length) than a 5 speed. And a SD and obs transfer case arn't interchangable
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #8 of 14 (permalink) Old 09-22-2009, 05:37 PM
What else?
smokyred's Avatar
To put a zf6 in an OBS you have to move the trans crossmember back, as well as change driveshaft lengths, our shop did one several years ago.
Dave
smokyred is offline
post #9 of 14 (permalink) Old 09-27-2009, 08:02 PM
Have you started on your swap yet
Doyle is offline
post #10 of 14 (permalink) Old 09-27-2009, 08:23 PM
cattle farmer
powerstroke742008's Avatar
also on the zf6 the dowl pins (sp)? on the motor are in different spots then the zf5 but it wouldnt be hard to make work
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
