E40D DOA on side of the road - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 09-19-2009, 03:43 PM Thread Starter
Old But Sexy junkie!
NastyCracker's Avatar
Drove the truck down the road to test out injector re-build. Went to turn around and had no reverse. Put it in drive and nothing. I tried 4 wheel high & low, nothing, nothing anywhere, foward or reverse.
Here's the strange part. Temp was at 160, no flashing OD light, no codes in my scanner (preditor), no leaking fluid, fuild is clean and doesn't smell burnt. I checked the linkage, it's solid. I still have park. Got pulled home from the side of the road, had it in nutral. I've checked all my fuses, rear sensor in the axle and connector to the trans, everything seems to be OK.
What am I missing?
Brad
NastyCracker is offline
post #2 of 18 (permalink) Old 09-19-2009, 05:12 PM
What else?
smokyred's Avatar
Re: E40D DOA on side of the road
Nothing even if you dropped it into drive and throttled it up quite a bit?
Do you have a gauge that you can check line pressure at the test port on the side of the transmission? That's strange you don't have anything all of a sudden.
Dave
smokyred is offline
post #3 of 18 (permalink) Old 09-19-2009, 05:23 PM Thread Starter
Red, If I rev it up, it'll creep ever so slow, but man its not even a crawl. Does the same either in Forward or Reverse.
No, I don't have a line pressure gauge. Is there a field in my Preditor scanner maybe?
And yes, VERY strange to lose everything without notice.
post #4 of 18 (permalink) Old 09-22-2009, 01:39 PM Thread Starter
Pulled the back cooler line, started truck, have plenty of flow. Taking the truck to a shop at this point.
post #5 of 18 (permalink) Old 09-25-2009, 01:08 PM Thread Starter
Shop reports TC failure and no telling what after that. I don't understand if I have flow, why the TC is shot.
post #6 of 18 (permalink) Old 09-27-2009, 12:05 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
How are flow and a failed torque converter related? If the torque converter fails it doesn't stop the pump from working. The two are not related, though they are next to each other inside the trans.
Mark Kovalsky is offline
post #7 of 18 (permalink) Old 09-27-2009, 06:15 PM
FNG
Dave's Avatar
Damn that sucks Brad. Hope you get it fixed up right. Thats one of the sweetest OBS trucks I have ever seen
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #8 of 18 (permalink) Old 09-28-2009, 02:39 PM Thread Starter
Thanks Dave & Mark.
As you can no doubt tell, I know little about transmissions other than buy them often.
Getting it towed home now. Anyone know how to test the solenoid pack in this unit?
post #9 of 18 (permalink) Old 09-29-2009, 07:47 AM
Yes, but why bother? It's not the solenoids. There is nothing electrical that will prevent it from moving. This is a mechanical failure. It has to come out and get replaced or rebuilt.
post #10 of 18 (permalink) Old 09-29-2009, 01:37 PM Thread Starter
Thanks Mark, going to get started on pullin it out today.
