question on rebuilding 4r100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-16-2009, 12:04 AM Thread Starter
im gona be pulling my tranny out of my 99 to fix second gear an put a new tq converter in.iv never done this before iv done everything else motor wise to my truck is their any special toles i need an do i have to look out fot when taring it apart?.thanks guys for the help.
1999 ford super duty ex cab short bed 4x4 dp-tuner f-5 lomp mod,80 econ,100,120 race,140 aggresive 4inch exaust to 6-inch tip non-wastegated housing upgrade from bts di-performance crossover line di-performance fuel tank mixing delete autometer gauges boost,trans,pyro custom made cold air intake.
big bad stroker is offline
post #2 of 4 (permalink) Old 09-16-2009, 05:33 PM
NorCalDiesel's Avatar
Re: question on rebuilding 4r100
Well, you should probably start by reading the ATSG manual and supplement for the 4R100 / E40D. It points out all the unique tranny tools you will need as well as all the unique parts, concepts and functionality you will be working with while inside the case.
I don't know what you mean by fixing second gear, but I assume you may be opening the case. Personally, if I was opening the case to fix something, I would really consider buying a full rebuild kit and doing it all while in there.
Definitely read the ATSG manuals, if nothing else you will understand more than you do now. I have only rebuilt a TH400 many years ago and it worked well for a long time. I am considering doing my 4R100, but I am not ready to dig in yet. It is not similar to rebuilding an engine, IMHO
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #3 of 4 (permalink) Old 09-16-2009, 07:28 PM
secondarychaos's Avatar
it's definitely different from an engine rebuild; but i've heard great things about the tools and instructions from racerxautomotive.com . if you have a strong mechanical ability, it shouldn't be a problem. I would also consider a set of HD clutches and steels.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #4 of 4 (permalink) Old 09-16-2009, 11:26 PM Thread Starter
thanks guys i will definitely get a manual for sure..an second gear has been gone for more than a year i had a ford dealership rebuild it an it shifted so hard from first to second it would break the tires lose then sumthen broke i replaced alot of simple things thought that might be the problem but no fix so the problem is inside after the issue is fixed brian is gona hook me up with a real tranny im am a competive person with my ford but it does me no good when my tranny isnt workn right.
