Obs needs more clutch power for dual disk?cummins - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-07-2015, 05:12 PM Thread Starter
Brian
Orangeracer's Avatar
Send a message via AIM to Orangeracer
So I have a 5 speed single disk in my 92 sd 5 speed cummins and south bend 500hp clutch. Shifts flawlessly releases halfway down on pedal. Then I swapped a cummins into my 96 f250 and have had nothing but problems I keep throwing parts at it an can't seem to get the clutch to release unless it's to the floor into the carpet an even then it doesn't want to, had stock style clutch an then did a dual disk an same problem! Replaced master an slave an still have same problem! Does anyone know of an upgraded slave cylinder?
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Orangeracer is offline
post #2 of 5 (permalink) Old 02-07-2015, 05:13 PM Thread Starter
Brian
Re: Obs needs more clutch power for dual disk?cummins
Photo of truck
post #3 of 5 (permalink) Old 02-07-2015, 11:53 PM
m j
m j's Avatar
is the slave moving at 1:1 with the master? it doesnt sound like a slave issue. you either dont have it bled or the fork is not correct
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #4 of 5 (permalink) Old 02-09-2015, 02:34 AM Thread Starter
Brian
I ordered ford parts. We will see
post #5 of 5 (permalink) Old 02-19-2015, 12:45 AM
Bent/wrong fork?
Ja_cain is offline
