Torqe converter locking up at idle....I think - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-15-2009, 04:59 AM Thread Starter
On EVERY fresh cold start, when I put the transmission in gear (forward or reverse) the torqe converter acts like it is trying to lock-up and it really lugs-down the engine. Anyone have this problem.
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
post #2 of 11 (permalink) Old 09-15-2009, 05:01 AM
FordCowboy's Avatar
Re: Torqe converter locking up at idle....I think
Not on starts but I had it happen when slowing down for a stop light or something. For my case the usual problem is the solenoid pack. It controls the TC lock up. Replaced it but then blew the rest of the trans up so I don't actually know if it worked or not. They are expensive from Ford like $400 or more, but you can find them cheaper.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #3 of 11 (permalink) Old 09-15-2009, 10:14 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
It's rarely the solenoid. It can be, but not usually.
Most often it is low trans fluid. It can also be a loose internal filter, leaking internal seals, a worn pump, or a bad converter. I listed them in the order of most likely to least likely.
Mark Kovalsky is offline
post #4 of 11 (permalink) Old 09-15-2009, 11:53 PM
Oordski
Oordski's Avatar
I have had a alt do that it will give off ac ripple and mess with the output speed sensor.
02 7.3 L Powerstroke 4 door with DP Tuner, Wicked Wheel, 1.0 Housing, Terminator pumps, Single Shot AC Injectors, BD Converter, Billy Built Tranny, 4.30 Gears, 325/65R18 Tires, and For Mama:Captain Heated Seats all the way around and 2DVD Screens, In dash GPS. Newly added: 51 gallon Titan fuel tank, Airdog II, CCV, QSSB from Wideopen Performance
Oordski is offline
post #5 of 11 (permalink) Old 09-16-2009, 12:11 AM
Snake Oil Salesman
mattr66's Avatar
Plugged cooler or lines?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #6 of 11 (permalink) Old 09-16-2009, 12:43 AM
Bigfoot is an OBS
cowboy_dan's Avatar
Now that I highly doubt. My cooler was about 98% plugged before BTS. I never had trouble with it pulling the engine down when put in gear. But, maybe that was because the stock converter was worn out?
Go ARMY!
cowboy_dan is offline
post #7 of 11 (permalink) Old 09-16-2009, 02:46 AM Thread Starter
Brand new 6 liter cooler installed...didn't check the lines.
schmity is offline
post #8 of 11 (permalink) Old 09-16-2009, 02:51 AM
Oordski
Oordski's Avatar
If its the ic you just installed the transmission cooler lines ar tight on the passenger side. usualy haft to massage them a bit
Oordski is offline
post #9 of 11 (permalink) Old 09-16-2009, 05:06 AM Thread Starter
Brand new 6.0 L transmission cooler. The lines are on the bottom so that the 6.0 IC will fit.
schmity is offline
post #10 of 11 (permalink) Old 09-16-2009, 05:10 AM
Oordski
Oordski's Avatar
Cool cool
tryin to help
Oordski is offline
