clutch ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 09-14-2009, 03:32 PM Thread Starter
clutch ?
has any one used this clutch? from the looks of it , it looks to have a dual mass flywheel which I not sure I want to go that route.
Beans Diesel Performance - 99-02 Power Stroke South Bend Con OFE 6 Speed Clutch (Powered by CubeCart)
[SIGPIC][/SIGPIC]2000 f-350 7.3 4x4 crew 6spd longbed srw
afe II, Garrett 38, dynomite stage II single shot, DI reg. return, fass150/180, CRM hpop, hx crossover, ccv mod , fs2500 by-pass oil filter,DP recal. ECM, DP custom live tunex2, moded IDM, 4" turbo back, Banks power elbow
410hp/863tq straight #2
jefsred350 is offline
post #2 of 8 (permalink) Old 09-14-2009, 03:42 PM
JHill's Avatar
Re: clutch ?
it should be not a dual mass, and it is a good clutch. ran that one before i went to a DD
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #3 of 8 (permalink) Old 09-14-2009, 03:46 PM Thread Starter
Re: clutch ?
thanks for the reply just going off the pictures and the description
post #4 of 8 (permalink) Old 09-14-2009, 09:15 PM
Pulling sled for hire
ParkerFly's Avatar
Re: clutch ?
It uses a single mass flywheel that comes with the kit. Most people seem to be really happy with it. I'm running it and like it.
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #5 of 8 (permalink) Old 09-14-2009, 11:24 PM
Power by IH
Stroked550's Avatar
Send a message via Yahoo to Stroked550
Re: clutch ?
If your going to do a LOT of heavy towing get the spicer disc instead of the regular LUK. Its not quite as smooth (more vibration/noise) but its a lot tougher.
2000 F-550 CC, 2wd, 6 speed. Homemade bed, 5" exhaust, DP chip, water inj, intake, gauges, ect
Stroked550 is offline
post #6 of 8 (permalink) Old 09-15-2009, 05:52 AM Thread Starter
Re: clutch ?
well it arived today, just from the looks of the pressure plate and disk I'm NOT impressed! have been persuaded by Mr.hill from another post to give it a shoot.
post #7 of 8 (permalink) Old 09-15-2009, 01:23 PM
ParkerFly's Avatar
Re: clutch ?
You're going to like it. The pedal pressure is half what a stock clutch is, and I'm running 463 hp through it (it's a 450hp clutch) with no problems. It's probably the most popular aftermarket clutch out there.
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
post #8 of 8 (permalink) Old 09-15-2009, 01:50 PM
JHill's Avatar
Re: clutch ?
jefsred350 ,
have you looked at other clutches available? there are alternatives out there.
that bieng said, you will find SB's cutomer service 2nd to none. if your uneasy with your putchase, call Peter and have talk with him. He will be glad to explain the differences in detail. good luck whatever you decide
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
