flex plate question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-12-2009, 03:52 PM Thread Starter
flex plate question
i just replaced my flex plate. the center was complety broken. the only thing that was leaking was the front pump seal. my question is did i brake anyting else by chance.
anthony
rockets10510 is offline
post #2 of 3 (permalink) Old 09-14-2009, 02:07 PM
Ears93's Avatar
Re: flex plate question
My van wouldn't move when I replaced mine due to the busted front pump when the flexplate broke the same way. I'm assumeing that yours is driveable since you didn't mention it and you said you already replaced?
Nick
Nick
97 E350
Muffler+Cat Delete with a 6inch MBRP Tip
Rebuilt E4OD with updated steel drums, updated planetary set, additional clutches, heavy duty torque convertor, shift kit, an additional cooler, and a few other updates.
More to come but I won't bore you with that till it's done.
Ears93 is offline
post #3 of 3 (permalink) Old 09-16-2009, 01:20 AM Thread Starter
i was driveing mine up until i pulled the transmission to find where the noise was coming from.
anthony
