Transmission apparently controlled by crackheads on meth. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-27-2015, 01:08 AM Thread Starter
So I just got my early 99 F250, and while driving easy the transmission shifts nice and smooth...but when you get on it, it gets confused going into 3rd and OD and will go in and out harshly (sometimes), also my TCC is crazy...when you get on it some (about 3/4 throttle) it'll lock in, then when you ease off the throttle to cruising speed (maybe 1/4 throttle) it unlocks and won't lock back in until you are hammering on it again. Fluid looks and smells ok and it never slips...I know these trucks don't shift wonderfully, but I'm wondering if this is normal or if I have bigger problems...
RattlinFord is offline
post #2 of 13 (permalink) Old 01-27-2015, 02:40 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Transmission apparently controlled by crackheads on meth.
Are there any codes stored in the computer's memory?
Mark
Mark Kovalsky is offline
post #3 of 13 (permalink) Old 01-30-2015, 12:51 PM Thread Starter
Not that I've seen. My buddy works at a Ford dealer and hooked it up on their computer and didn't see any. To give kind of an update on its operation...this should be more clear (I was tired when I posted that)
Normal operation (not a lot of throttle, no load):
Shifts normal and smooth as silk...but the TCC doesn't kick in under normal operation...you have to be at about 50% throttle to engage it...and it disengages at around 25% throttle...very frustrating.
Loaded operation (either towing or heavy throttle):
Shifts normal on the 1-2 shift, sometimes on the 2-3 shift...RARELY on the 3-4 shift. Normally slams into 4th. Again, TCC doesn't lock in until 50% throttle. Then unlocks when you go to cruising throttle. So, with a trailer, it's in/out/in/out/in/out...
No codes show...trans fluid looks and smells great. No slippage that I detected...I've been a mechanic 16 years but transmissions are NOT my specialty. Friend did a KOEO and a KOER test as well...with the Ford computer...
post #4 of 13 (permalink) Old 01-30-2015, 02:16 PM
My SWAG* is that you have a bad throttle position sensor.
*SWAG = Silly Wild A** Guess
Mark
post #5 of 13 (permalink) Old 01-30-2015, 08:50 PM Thread Starter
Lol I always say Scientific Wild Ass Guess! I put it on my scanner today, here are some things I noticed. It's shifting right when it's told. Doesn't appear to have excessive slip. Clutch coast solenoid never seems to engage. When floored, APP only registers 75%...I'll have to give the TPS a shot...transmission feels great, just feels like it's not getting the right inputs.
post #6 of 13 (permalink) Old 01-30-2015, 09:09 PM
The coast clutch solenoid should only engage when you turn off OD with the button on the end of the shift handle.
Mark
post #7 of 13 (permalink) Old 01-31-2015, 01:08 AM Thread Starter
Oh I see...like I said, not a trans guy. Where would you recommend getting a TPS from?
post #8 of 13 (permalink) Old 01-31-2015, 03:55 PM
I usually get parts from a parts store, a Ford dealer, and lately, Rock Auto.
Mark
post #9 of 13 (permalink) Old 02-02-2015, 11:02 PM
Having almost exactly the same issues. Interested to know if a tps fixes it
Excavator86 is offline
post #10 of 13 (permalink) Old 02-18-2015, 01:07 AM
BigRed02
BigRed02's Avatar
Mark, would you recommend aftermarket valve bodies (or other parts/kits for that matter) for these transmissions?
Mine does fine, but at lower cruising speeds, it likes to lurch into 4th with the TC locked. There's a lot of hear say on what I "need".
Don't mean to hijack!
Thanks, Spencer
2000 F350 CCLB 4x4 7.3L, 4R100, 6637, 4" MBRP turbo back
2000 F250 Red 4x4 Ext. Cab, 7.3L DI, ZF-6
2005 Ranger Dark Gray, FX4, 4 dr, 4.0 SOHC, 5r55e
2015 Ford Transit 3500, Dark Gray, HR EX, 3.5L ecoboost, 6 speed select shift
2011 Edge Limited Black, 3.5L
BigRed02 is offline
