Auto Trans. problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 01-26-2015, 08:44 PM Thread Starter
2003 F250 Superduty 7.3 OD light blinking doesn't want to shift from 1st to 2nd. Haven't had codes read yet afraid to drive to far. Could it be the shift solenoid ?
dthunt3 is offline
post #2 of 3 (permalink) Old 01-27-2015, 02:41 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Auto Trans. problems
It could be. Without the codes nobody knows.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 02-04-2015, 10:07 PM
Young&dumb
Will it manually shift if not you can read codes my best experience is hooking a pressure gauge up to the port on the side of the trans and seeing what you have! Little history of burnt fluid or slipping could help us also tell you if it's bad solenoids or burnt up clutches... But those soleniods imo go out because of the metal fibers in burnt up steels and fractions kinda a hint most of the time things are getting a little loose!!
Wpdiesel is offline
