4R100 Rebuild? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-10-2009, 07:39 PM Thread Starter
CtG
4R100 Rebuild?
How hard would it be for someone who has not done an Automatic before to do this?
I am confident in taking most things apart, I just need to understand what is involved first. As such I might pick up the ATSG manual and read it through a few times before taking it up.
But...
Our 02 Excursion with about 130k on the clock is starting to do what I'd deem slipping. You have to give it a lot more goose on hills and towing to get the same affect you would have 30k ago. It doesn't seem horrible... Yet, but it is getting worse. This thing doesn't need to hold 4 billion horsepower, heck, we rarely ever even have the Superchips tune in it. For the most part, it cruises around with its bigger exhaust, K&N filter, and Larry's Black Box and thats it. No lift, stock sized tires, etc. It just tows. Our camper, both our boats, our flatbed with "insert stranded car here" on it... So it needs to keep up the job its been doing so well for so long is all.
I was looking at the SunCoast Extreme Duty Master Rebuild and 4-clutch coast to serve as a basic upgrade. Any thoughts in that area?
When its not towing, it usually serves as moms daily driver, and she has always loved the buttery shifts.
Also... I heard a rumor about a TC that uses the 5R110 stator, and is significantly more efficient? Is this true?
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #2 of 5 (permalink) Old 09-10-2009, 07:47 PM
Starting Over
kainers's Avatar
Re: 4R100 Rebuild?
There is a TON of little parts in those things.Me personally would never attempt it.If you feel confident and have another rig to drive go for it.Worst possible thing is you have to dump all the parts to a Trans shop to put it back together.
kainers is offline
post #3 of 5 (permalink) Old 09-10-2009, 07:52 PM
Heath
rollingthunder's Avatar
Re: 4R100 Rebuild?
Check out Racerx. I think there is a write up at TDS from him with step by step and pics. Bill is a great guy and will back you up if you have problems during the rebuild. I had him build me one(I needed one right away). There was a problem with one of his machines which delayed things a couple of days so he upgraded mine from a stage one to a stage two with billet shafts and tailpiece and TC to make up for the delay.
2005 250 crewcab king ranch
arps, egr delete,coolant and oil bypass filters
4" turbo back MBRP
A-1000 fuel w\Reg return
Warrne 175\30's
rollingthunder is offline
post #4 of 5 (permalink) Old 09-10-2009, 08:54 PM
moore20017.3's Avatar
Re: 4R100 Rebuild?
I did one once in an 96 F150. I did not even touch the valve body, sent it to a shop. Installed it and it would do nothing. Ended up sending it to the tanny shop to get it right. I was sold the wrong converter and it ate up the input shaft and the whole tranny had to be rebuilt anyway.
Long in short, don't even mess with it. My trying to save a little change cost me twice as much in the long run and I had to take it out and put it back in twice.
There are a lot of small parts and a lot of things that a builder just knows from experience. I learned my lesson on that one.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #5 of 5 (permalink) Old 09-10-2009, 10:32 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: 4R100 Rebuild?
If you have the time to take your time, it's not bad. I helped my dad to 2 GM transmissions (one of them twice).
Poking along, I think each rebuild took about a week for us.
Bill's a good guy to talk to.
Go ARMY!
cowboy_dan is offline
