CLUTCH PROBS....HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-08-2009, 07:46 PM Thread Starter
i have a 2000 powerstroke with a southbend con fe clutch in it. now what my problem is that i can slip it slightly and when i disengauge it to stop it will not go back into gear. so what could be my problem........don't have enough power in my truck to slip that clutch by no means..
thanks in advance
2006 f-250 ext cab swb, 127,000mi, Egr delete, 4" tb exhaust, edge juice w/ cs.
Ryan
dp_stroker is offline
post #2 of 9 (permalink) Old 09-11-2009, 03:30 PM
JHill's Avatar
Re: CLUTCH PROBS....HELP
have you called SB? did you replace the throw out lever arm?
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #3 of 9 (permalink) Old 09-11-2009, 06:25 PM Thread Starter
i called southbend and they told me to remove the helper spring and bleed the slave cylinder. but when i did that nothing changed. the throw out lever arm? are you talking about the fork?
Ryan
post #4 of 9 (permalink) Old 09-15-2009, 05:04 AM
this is not what I wanted to read, just got one of these clutches. it arrived today now I 'm having second guess about putting it in. not at all what i was expecting for 900 bucks. looks to be a POS stock pressure plate and disk w/4 springs that I've seen picture after picture with the springs broken. I will wait to see if others will post . do not want to have to do this any more than i have to . sorry to interrupet will post a new thread.
[SIGPIC][/SIGPIC]2000 f-350 7.3 4x4 crew 6spd longbed srw
afe II, Garrett 38, dynomite stage II single shot, DI reg. return, fass150/180, CRM hpop, hx crossover, ccv mod , fs2500 by-pass oil filter,DP recal. ECM, DP custom live tunex2, moded IDM, 4" turbo back, Banks power elbow
410hp/863tq straight #2
jefsred350 is offline
post #5 of 9 (permalink) Old 09-15-2009, 05:16 AM
JHill's Avatar
yes, Ford as well as SB has an updated fork, may or may not be the problem
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #6 of 9 (permalink) Old 09-15-2009, 05:27 AM
JHill's Avatar
I would bet the pics you saw were off the pos stocker with the springs puked out, been there done that.
I ran this clutch for over a year with multiple hooks to a sled, and one were I smoked the heck out of it, let it cool down and ran it for a few more months before I finished it off playing in the sand.
If you look at the disk surface it is much narrower than stocker.
I would not hesitate to run it again if i were to run a single disk again my .02
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #7 of 9 (permalink) Old 09-15-2009, 05:31 AM
JHill's Avatar
the only thing I didnt like was it was noisy in neutral
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #8 of 9 (permalink) Old 09-15-2009, 05:37 AM
thank you Mr. Hill. will consider it.
post #9 of 9 (permalink) Old 09-15-2009, 08:26 PM Thread Starter
thats the one thing i don't like about it (the noise). but as far as complants go i have none up until this but i will be the first one to admit i'm not real easy on it either. she see's 10k+lbs monthly.
Ryan
