E40D Problems! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 09-07-2009, 06:12 PM Thread Starter
masterteee89's Avatar
E40D Problems!
I have a 97 F250 PSD and something is badly wrong with my tranns. I was up camping this last week and im only towing maybe 2000lbs (two ATV's, 16ft Flatbed). I was driving and i noticed i was just losing power all of the sudden. I looked over and my OD light was flashing. The truck began to shift really hard! Get to camp and i threw it in reverse and the truck sounded like it was gonna stall... RPM's dropped and the truck sounded like it was barley running. Tried backing up and i had no reverse power what so ever. Now when im in reverse and i shift into drive the truck would like jump forward as if my foot was on the gas and i put it into drive. On the drive home yesterday same thing OD light flashing and really hard shifts! Get it home and couldnt even back my trailer up in the driveway! Same problem.
So... does anyone have any idea whats wrong??? I don't know much of anything about transmissions. Hope i explained the problem good enough to understand!
Thanks!
1997 Ford F-250HD 4x4 SC/LB PSD, 128,000 Miles
MBRP 4inch Straight Pipe w/cat delete and 3inch DP and MBRP 6in Tip
Tymar Intake
Front add-a-leafs w/Skyjacker Nitro 8000 shocks all around.
BFG All Terrains 315/75/16 on Stock Wheels
masterteee89 is offline
post #2 of 19 (permalink) Old 09-07-2009, 06:52 PM
ADubDiesel's Avatar
Re: E40D Problems!
Sounds like your getting ready for a rebuild... What does the fluid look like?
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #3 of 19 (permalink) Old 09-07-2009, 06:54 PM Thread Starter
Re: E40D Problems!
I had a tranny flush about 2 months ago. Fluid was clean.
Tymar Intake
post #4 of 19 (permalink) Old 09-07-2009, 08:00 PM
Re: E40D Problems!
gonna have to get a scanner and find the codes, since the od light is flashing that means a code has been stored.
now when you say you shifted into drive it acted like you were on the gas? sounds like maybe the tc didnt unlock.
02 f250
countryboyrob is offline
post #5 of 19 (permalink) Old 09-08-2009, 03:00 AM
Gone Broke
Stroker96's Avatar
Re: E40D Problems!
mine did the same thing,, and i had to rebuild it
08 F-350 CC SB King Ranch 4x4
H&S Black Maxx 300 tune, Unlimited Intake, 6" Exhaust, Fuel Nutz wrapped with 295 Trail Grappler's
2000 F350 6spd Powerstroke For Sale!
UNLIMITED DIESEL PERFORMANCE
Stroker96 is offline
post #6 of 19 (permalink) Old 09-09-2009, 09:47 PM Thread Starter
Re: E40D Problems!
Is it safe to drive for now until it completely blows up?
Tymar Intake
post #7 of 19 (permalink) Old 09-09-2009, 11:41 PM
Stone Crusher
trackspeeder's Avatar
Re: E40D Problems!
The truck starts, stops, all the lights work. It's plenty safe to drive.
The tranny will not like it. You might want to fix it before it blows up. A live tranny can be cheaper to rebuild than a dead one.
01 F250 XLT 4X4 Auto trans, Dark Highland Green, Green fuzzy dice,Di Pricol Optix gauges,Dura Lite air cleaner,CCV mod,coolant filter,,AIC,XM Satilite radio.
trackspeeder is offline
post #8 of 19 (permalink) Old 09-10-2009, 01:17 AM
That thing got a Cummins?
nasty96's Avatar
Re: E40D Problems!
If I don't have the truck from the second it rolls off the lot or has had the trans rebuilt, I never flush the fluid, or even change it. All the crud in it is the only thing keeping it together. I'd give bts or suncoast a call and get a trans build date reserved now because the trans probably won't last another month or two. BTW your speedo still work? No blown fuses anywhere?
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #9 of 19 (permalink) Old 09-10-2009, 01:27 AM
ADubDiesel's Avatar
Re: E40D Problems!
My dad says the same thing. I'm gunna run mine til it dies. When it does, it's BTS time!
post #10 of 19 (permalink) Old 09-10-2009, 09:06 PM Thread Starter
Re: E40D Problems!
Yeah everything works fine other than my stupid trans! The OD light keeps flashing but i was reading somewhere and it says... when OD light is flashing a trans malfunction has been detected and will perform in a failure mode.
Tymar Intake
