Problems after Transgo tugger install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-06-2009, 08:15 PM Thread Starter
Just finished up an install and got a problem.
The truck wont shift into second unless I let off the gas. It will just go straight into redline even with a light pedal.
Any clues to what I might have screwed up?
RamIt is offline
post #2 of 3 (permalink) Old 09-07-2009, 01:47 AM Thread Starter
Re: Problems after Transgo tugger install
A little more details:
1st will not up shift unless I get off the gas or manually shift into second.
Seems to just bypass 3rd all together and goes straight to OD.
OD switch no longer works as it will not shift into 3rd.
If I punch the gas in OD at about 45 it will try to down shift into 1st.
RamIt is offline
post #3 of 3 (permalink) Old 09-08-2009, 02:42 AM Thread Starter
Found out I had neglected to install 2 check balls in the main valve body sandwich.
Trans works very well now.
The instructions are way too vague to recommend this kit to the average Joe.
RamIt is offline
