Hard shifting....... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 09-04-2009, 01:45 PM Thread Starter
Fire junkie
Here about a mth. ago I changed the fluid and filter in my E4OD, shortly before that ~a week or so, it started shifting REAL hard into 4th, I took it to a friend of my dads who has a trann. shop, he pulled the valve body out and said that the #4valve had a "small burr" on it, so he polished it down, that same weekend I went to the mtns. to start scouting for my elk hunt on the way out (road is very winndy up / down, etc) it started shifting even HARDER into 4th, when I got home took it back in to him his thought was to pull one of the springs out? (it has a tranns go shift kit from a privious rebuild) however it is still doing it, the weird thing is it does not do it every time or if you get on it hard or soft, I have also noticed that my tranny temp is running just alittle highter than it normally does, any ideas out there?, thanks
stay safe out there
Roy
96 F250 C.C. , Rebuilt E4ODx2, open air intake, Hypermax downpipe,straight 4", Stage 1's, Autometer EGT, Boost, & Tran temp, Upgraded trannie cooler, Custom home built front & rear bumpers, head ache rack and 60 gal. Aux. fuel tank
Truck4 is offline
