auto tranny help/info - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-02-2009, 04:19 AM Thread Starter
So my dad bought a 99' 350 with an auto Its the first automatic in our fleet
Any way, Drives good but We cant seem to get the OD light to flash on, which I guess is taking it out of overdrive yeah ?
Any info on this thing would be good..
Truck has 95k miles all stock..
Mahalos
96'
F250 Some stuff
Bamboo is offline
post #2 of 7 (permalink) Old 09-02-2009, 04:22 AM
96 Ford F-350 PSD
Ford3544's Avatar
Re: auto tranny help/info
My dads 00 dually had the same problem. Very common. The shift lever breaks the wires inside over time to the switch. Ford has an upgraded one that now has worked great for about 15,000 miles. It is easy to replace too. I had it fixed in about 20-30 mins. Just pull the steering cover off, pull the pin for the shift lever and fish out and replace.
96 Ford PSD! Custom intercooler, 01 Aluminum radiator, S&B Intake, 5" exhaust, Stage 2 injectors, Complete stud kit, 3" aluminum intake plenums, Fuel system w/aeromotive pump and regulator, Coolant filter, BTS Trans, Adrenaline HPOP, live tuned DP Tuner, 4" lift, MKW19 wheels and Toyo MTs.
Ford3544 is offline
post #3 of 7 (permalink) Old 09-02-2009, 04:35 AM Thread Starter
do you know what parts I need ?
Thanks for the quick response.
96'
F250 Some stuff
Bamboo is offline
post #4 of 7 (permalink) Old 09-02-2009, 04:48 AM
96 Ford F-350 PSD
Ford3544's Avatar
It comes in a complete kit. Tell them you need the shift lever overdrive button assembly. Like I said it is common, so they should know what you are talking about. I live in a small town and they had it in stock.
Ford3544 is offline
post #5 of 7 (permalink) Old 09-02-2009, 11:06 PM Thread Starter
Ok, got the piece
any tips on removing the steering cover? Not nearly as straight forward it seems as my 96'
and I dont want to go breaking plastic clips on my dads truck...
96'
F250 Some stuff
Bamboo is offline
post #6 of 7 (permalink) Old 09-03-2009, 01:22 AM
96 Ford F-350 PSD
Ford3544's Avatar
It is really easy. Unscrew the handle to change the tilt, and then you have 2 or 3 screws on the bottom side to lossen and then a couple tabs on the sides that need to be undone and then drop the bottom side, The top side can be fliped up and then undone from the shift lever. R&R shift lever and put back together.
Good luck.
Ford3544 is offline
post #7 of 7 (permalink) Old 09-03-2009, 02:42 AM Thread Starter
Got it! thanks alot, once I peaked under there it all made sense
Aloha
96'
F250 Some stuff
Bamboo is offline
