inputshaft ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-01-2009, 12:09 AM Thread Starter
I pity the fuel
hutchnoclutch's Avatar
inputshaft ???
So I just got a new pump for my e40d from racer x and after installing it the input shaft wont slide out by hand. Now with the old pump I could slide the input shaft in and out very easily. So my question is: Is this because there are new seals holdingit in tighter? Or did I not install properly? I've taken it outand put it back in and everything seems ok????
97 F 250 TW CHIP,IDM MOD,3'' DOWN PIPE, 3" INTAKE & SPYDER, GUAGES,DIY TYMAR,MAG HYTEC TRANS PAN,Dominator 66 :,adrenaline,Beans fuel system
rosewood 230cc hybrids,:arp studs,intercooler,
hutchnoclutch is offline
post #2 of 4 (permalink) Old 09-02-2009, 02:19 AM
5ninef250's Avatar
Re: inputshaft ???
Did you install the pump using the old input for alignment?
1997 F250 4X4, E4OD, 12v, SDX 5x14's & DV's, benched pump, 20*, 66/71/13SS, City Diesel 6OH I/C, D60 RSK, SD Springs
1997 F350 CC 4X4, Hypermax Stage 2's, H2E, BTS pumps, BTS trans, Banks I/C
5ninef250 is offline
post #3 of 4 (permalink) Old 09-02-2009, 02:21 AM
Don't EFN worry about it
Aljay's Avatar
Re: inputshaft ???
How did you keep the torrington bearing in place while you bolted the pump in?
Tuned by T Wildman
Aljay is offline
post #4 of 4 (permalink) Old 09-04-2009, 12:18 AM Thread Starter
I pity the fuel
Re: inputshaft ???
i did use the old input shaft for allignment and a little fluid on the bearing kept it in place.
i took the pump out twice and just not sure, I' m a plumber not a mechanic which is part of the problem, I'm sure!!
