2006 F250 Tow/haul and no gears but have pressure on 5R110W - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 12-24-2014, 11:52 AM Thread Starter
Hey all I was driving down the highway and the truck was in overdrive and under a load passing at about 20lbs boost and all of the sudden I lost all power, felt truck shake a little. The tow/haul light is flashing and got only one code P0730. The truck won't go into gear in either forward or reverse now, had it towed home and put a pressure gauge on it and found about 100psi at idle In neutral, in reverse and forward I got strange readings the pressure goes way up momentarily then down to 100psi, and increments back up to over 500 psi and seems to stay there but neither forward or reverse engage. I have no clue what could be wrong at this point. I am attaching a video so you guys can see what I'm talking about. Any help would be totally appreciated. Thanks for looking guys.
2006 f250 5r110 transmission failure with P0730 - YouTube
proamas is offline
post #2 of 12 (permalink) Old 12-24-2014, 12:08 PM
Administrator
Zmann's Avatar
Re: 2006 F250 Tow/haul and no gears but have pressure on 5R110W
I See you found the PSN welcome !
I hope someone here can dial you in
maybe Mark K will swing by and give some Holiday Help ;-)
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 12 (permalink) Old 12-24-2014, 01:40 PM Thread Starter
Thanks Zmann, i sure hope so.
proamas is offline
post #4 of 12 (permalink) Old 12-24-2014, 02:00 PM
Administrator
Zmann's Avatar
unless He is playing Santa Clause today at the local mall ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 12 (permalink) Old 12-24-2014, 02:21 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Ho, ho, ho, no. I'm not playing Santa this year.
Something mechanical broke inside the trans. I don't know exactly what broke, you'll find that out when the trans is torn down.
Mark
Mark Kovalsky is offline
post #6 of 12 (permalink) Old 12-24-2014, 04:16 PM
Administrator
Zmann's Avatar
Merry Christmas
so My wild arse guess based soley on the single code on another forum that a solenoid may not be in the proper position was totally wrong ( I validated the guess with a disclaimer " I don't know anything" lol)
glad i pointed him here ;-) even if it was for bad news
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 12 (permalink) Old 12-25-2014, 03:33 AM
matthewd11's Avatar
Where are you located?
Definitely sounds like a large mechanical failure which will require disassembly.
matthewd11 is online now
post #8 of 12 (permalink) Old 01-02-2015, 06:44 PM Thread Starter
Ok so my trans guy is still on vacation so I pulled out my Auto Enginuity and monitored this below, any ideas????
P0730 overdrive clutch failed off
Transmission over temp lockup mode faulted
In park sol A = 49psi
In reverse sol A = 203 psi
In drive sol A = 125 psi
In rev Sol E = 299.93 psi
In park
Inputs shaft speed = 655 rpm
Intermediate shaft speed = 445
Output shaft speed = 0
Reverse
Intermediate shaft speed = 0
Output shaft reliable faulted giving throttle
2006 F250 Lariat
EGR Delete
SCT Livewire with Innovative tunes
Blue spring upgrade
Sinister Coolant filter
5" Diamond Eye SS exhaust
8" Rough Country lift with 37" Toyo MT's
proamas is offline
post #9 of 12 (permalink) Old 01-02-2015, 10:11 PM
Those pressures don't mean anything. There are no pressure sensors in the transmission. Those values are what the PCM wants for pressure, not what is really happening. Have you verified that there really is pressure?
Mark
post #10 of 12 (permalink) Old 01-03-2015, 05:19 PM
matthewd11's Avatar
Sent you a PM.
