Auto trans issues please help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-21-2014, 09:09 PM Thread Starter
Six Point Slow
justinstorm77's Avatar
I'm not very familiar with the ford auto transmission. When I let off the accel pedal it feels like the drive line is clunking. The same goes for stepping on the on the accel pedal, it seems to clunk a bit. You cant so much hear it as much as you feel it. The truck is getting close to 90k on it and I know it hasn't been beaten at all. front and rear diffs are tight, all u joints are fine. I'm leading toward a converter at this point. It also has a slight rough idle (engine is solid with no issues) but runs great under acceleration and deceleration. Trans shifts as it should. Anything to look out for would be a great help and much appreciated. Thanks in advance.
justinstorm77 is offline
post #2 of 4 (permalink) Old 12-22-2014, 12:43 AM
matthewd11's Avatar
Re: Auto trans issues please help
check the slip yoke in the driveshaft.
What kind of truck? No year, model, engine, etc
matthewd11 is offline
post #3 of 4 (permalink) Old 12-22-2014, 01:31 AM Thread Starter
Six Point Slow
2002 f250 7.3 auto. Everything I can put my hands on within the drive line is tight. I'm the lead tech at a international dealership. I know eaton and Allison transmissions. I know they put this ford trans in the CF model cab overs but the engines (VT275) never seem to last long enough or put out enough power to give these trans any issues in those so I hardly ever deal with them, plus I do most of the heavy diag and engine repairs. Slip yoke would be great, drive shafts are fairly cheap unlike trannies and converters.
post #4 of 4 (permalink) Old 12-22-2014, 07:12 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
No it isn't. I've looked at many, many, many of these and I never saw one that didn't have a lot of lash in the rear axle. That causes the clunk. It isn't in the transmission.
No, they never put this transmission in the CF cabover. It's successor, the 5R110, was in the CF. Similar, but a different transmission. The transmission you have is a 4R100.
Ford sells a special grease just for the slip yokes. It works really well. The slip yokes tend to bind and cause clunks, but usually not under the conditions you are describing. It is probably worth a try.
Mark
Mark Kovalsky is offline
