4R100 problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 08-30-2009, 12:02 AM Thread Starter
boostaddict's Avatar
4R100 problems
So ever since i got the truck the trans hasn't shift good with my chip, no idea what kinda chip. The other day i changed the fluid and filter and it helped my trans was shifting better. last night i was beatin on it and got on the freeway 6th setting and in overdrive and it never shifted in to high gear it stayed in 3rd. Today i was going to hook up a manual TC lock up switch but i'm color blind and think i scotch blocked the wrong wire. when i finished everything up i went to test it and 1st gear was slipping real bad. OD light started flashing so i went back took it all apart and now the light is still flashing....anyone have any suggestions? its still slipping even though everything back to stock. Fords closed and i don't know anyone around here with AE
Help! trucks in my Sig
boostaddict is offline
post #2 of 26 (permalink) Old 08-30-2009, 03:45 AM
tbolt's Avatar
Re: 4R100 problems
I would find out what chip is in it. More than likely it's the chip not the trans. Wiring the switch wrong I can't comment on. I let the tuner take care of that.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #3 of 26 (permalink) Old 08-30-2009, 03:48 AM
it's an 02 05 08
turbodiesel_02's Avatar
Re: 4R100 problems
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #4 of 26 (permalink) Old 08-30-2009, 06:19 AM Thread Starter
Re: 4R100 problems
I havn't had a problem with the chip till i did the TC lock up switch. i mean the trans didn't shift well but i never had the OD light come on. Even on the stock setting it slips so i don't think it has to do with the chip but correct me if i'm wrong i'm a newbie to the diesel world. Thanks for the input though!
post #5 of 26 (permalink) Old 08-31-2009, 01:10 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: 4R100 problems
A better valvebody couldn't hurt ya.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #6 of 26 (permalink) Old 08-31-2009, 02:01 AM
Re: 4R100 problems
Being that you tapped into the possibly the wrong wire and the OD lamp is now flashing, the transmission controller is now in "limp in" and in 4th gear.
You need to test all of your fuses and the fuse that powers the shift solenoids may be blown. Get someone to scan it to get the code or codes. That may point you in the right direction.
HammerHead is offline
post #7 of 26 (permalink) Old 08-31-2009, 04:47 AM Thread Starter
Re: 4R100 problems
thanks for the input i'm going to ford tomorrow to have it scanned.
post #8 of 26 (permalink) Old 08-31-2009, 06:58 AM
Re: 4R100 problems
od lites flashing? over a 100k? now ya add a chip? i maybe wrong but no 3rd or 4th that time? bout bet ya can be buyn a trans. i could be wrong....the codes will give ya an idea. mine lost 4th and then it shot a hole in the case and had trans fluid everywhere.
SIR-STROKEALOT is offline
post #9 of 26 (permalink) Old 09-01-2009, 03:27 AM Thread Starter
Re: 4R100 problems
so ford wanted a 100 bucks to scan it. so i said eff em and went to a buddys shop and used his snap on scanner. codes in KOEO mode in order....
P0750 Shift Solenoid A fault
P0755 Shift solenoid B fault
P0743 TCC System electrical fault
P1754 Coast clutch solenoid CKT fault
P0603 Internal control module KAM error
P0470 Exhaust pressure sensor CKT fault
P1746 Pressure control solenoid CKT open
P1747 Pressure control solenoid short CKT "EPC"
any help pointing me towards a possible bad solenoid would be great!
post #10 of 26 (permalink) Old 09-01-2009, 03:41 AM Thread Starter
Re: 4R100 problems
I'm leanin towards a need solenoid pack lemme know what you think. did some reserch and it appears i grounded the TOT sensor. If it is a solenoid pack is Ford the best choice?
