speedo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-28-2009, 11:06 PM Thread Starter
reis1995's Avatar
speedo
My speedo don't work at all until about 50mph and until it gets there and stays there for about 40 sec the od light flash's. But once i get to fifty every thing is fine and it reads fine but if i drop below fifty the speedo drops to 0 immediatly and the od light starts flashing again. Any ideas?
reis1995 is offline
post #2 of 7 (permalink) Old 08-29-2009, 12:00 AM
Layson's Avatar
Re: speedo
What type of truck do you have? Sounds like an ABS sensor?? Anybody around to read codes for you?
Layson is offline
post #3 of 7 (permalink) Old 08-29-2009, 03:12 AM Thread Starter
reis1995's Avatar
Re: speedo
early 99 f-250
reis1995 is offline
post #4 of 7 (permalink) Old 08-29-2009, 04:03 AM
Layson's Avatar
Re: speedo
Kind of sounds like a bad ABS sensor. See if you can find someone to read codes. You might beable to post up and find someone in your area with AE software. Where are you at?
Layson is offline
post #5 of 7 (permalink) Old 08-29-2009, 04:59 AM Thread Starter
reis1995's Avatar
Re: speedo
Western KY But that sounds right cause my friends truck just started doing the same thing. Only his starts working at 30 and his abs light came on. Thanks for the help.
reis1995 is offline
post #6 of 7 (permalink) Old 08-29-2009, 05:11 AM
Layson's Avatar
Re: speedo
There are three abs sensors. One in each front wheel bearing and one in the rear diff. If one of those are off then it will screw with the computer...
Layson is offline
post #7 of 7 (permalink) Old 08-29-2009, 05:21 AM Thread Starter
reis1995's Avatar
Re: speedo
i may be wrong but i don't think my truck has abs in the front so i'm almost positive it the one in the rear differ.
reis1995 is offline
