OD LIGHT FLASH???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 12-11-2014, 07:08 PM Thread Starter
OD LIGHT FLASH????
I know there's quite a few threads on this already but I want the most up to date info I can find. So here it goes I am new owner of this 2000 f250 with the 7.3 and it has some issues here and there that I need to address before it can be driven brakes etc. I take it out for a quick drive and the OD light was flashing when I looked down. I drove it around came home and went to grab my code reader and when I got back it was off. The fluid is up there and smells good. I also noticed that when I first tried to get it out of its spot on a slight incline no bumps just incline I kind of had to lay on the throttle. (I am new to the diesel thing by the way) Is this normal?? Seems like when going down the road you could mat the thing and throttle really wouldn't pick it up for a second or two, kind of hesitates. Maybe thats a whole separate issues but then again maybe not. It has 155*** on it and a Ts 6 chip not sure if that would affect it. The shift linkage is also loose not too bad and it doesn't want to go into 1 gear maybe the alignment is off.
Any and all help is appreciated I really dont want to do a tranny.
powerstrokeboy2000 is offline
post #2 of 11 (permalink) Old 12-11-2014, 07:19 PM Thread Starter
Re: OD LIGHT FLASH????
Forgot to mention also the only other light that is on is the ABS dont think that has anything to do with it but not positive. It doesnt seem to shift hard either.
post #3 of 11 (permalink) Old 12-11-2014, 08:27 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The ABS light may have something to do with it. You almost had your answer, but then you didn't check for codes. Do that and let us know what codes are stored in the computer's memory.
Mark
Mark Kovalsky is offline
post #4 of 11 (permalink) Old 12-11-2014, 08:31 PM Thread Starter
Thanks a bunch for your reply. I hear your the master of transmissions! I plugged in my code reader and it said no codes maybe I need to use a different reader you think?
post #5 of 11 (permalink) Old 12-11-2014, 09:55 PM Thread Starter
So I borrowed a reader and this is the LIST of codes that I found. I am just going to list them all because the one I feel could be irrelevant could be the winner. So here they are: PO541, P1670, PO478, P1298, PO380, PO603, F1784, PO500. This is depressing
post #6 of 11 (permalink) Old 12-13-2014, 02:34 AM
The P0500 is most likely the problem. That is a vehicle speed problem.
Mark
post #7 of 11 (permalink) Old 12-14-2014, 12:27 AM Thread Starter
Alright. Now where is the sensor located is it on the trans or differential??
Thank you for your time!
post #8 of 11 (permalink) Old 12-14-2014, 12:40 AM
rear diff sensor!
cory728 is offline
post #9 of 11 (permalink) Old 12-14-2014, 04:28 AM
Administrator
Zmann's Avatar
whats the f code ?
you have quite the spectrum going there
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 11 (permalink) Old 12-14-2014, 12:32 PM Thread Starter
I do have quite the array of codes, I have most of them figured out though. the f code I am not sure of I cant find anything on it.
I thank everyone for there help! I am going to grab a new sensor and see what happens!
