Manual Transmission problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-25-2009, 09:51 PM Thread Starter
vanderchevy18's Avatar
Hey I'm kinda having an issue on the work truck. It's not my toy so I can't really afford to have problems with it. It's a pre99.5 F350 with I think the ZF6(6 speed). The problem I'm having is that when it gets hot out or I'm working the truck hard in the hay field the clutch just seems like it's not disengaging. Now I know the problem and its the hose coming from my slave cylinder. The rubber is expanding when it gets hot instead of keeping pressure. Now what makes this performance related in (my mind) is I want to know if there is like a better line or "performance" line I can get. Like a braided line or something. If you could help me I'd sure appreciate it.
Thanks,
Chris
Chris
99.5 F250 CCSB 4X4 Auto- Bunch of stuff.
Irate Diesel Performance
1987 Mazda B2600 rclb with 2.3l 4D55T turbo diesel 4x4 5 speed manual trans. Being worked over with Irate magic. Nick named The Beast.
08 Kawasaki Brute Force camo 4x4- AMR 730xx big bore kit and bunch of other stuff. Nick named Excessive Force!!
vanderchevy18 is offline
post #2 of 9 (permalink) Old 08-25-2009, 09:56 PM
Stroker67's Avatar
Re: Manual Transmission problems
well chris, you posted in the wrong section, this should be in the 7.3 section, but im sure some other guys will chime in on the issue
Stroker67 is offline
post #3 of 9 (permalink) Old 08-25-2009, 09:57 PM Thread Starter
My bad!!!! There I got it! Sorry about that.
Chris
post #4 of 9 (permalink) Old 08-25-2009, 10:44 PM
HRT Performance
HotRodTractor's Avatar
I do not know of anyone that has made a decent replacement slave and master cylinder setup, but I did install a stainless steel line on mine when I was pulling. The fittings in the ends of the line are steel and are held in using dowel pins. I pressed the dowel pins out, temporarily removed the sealing o-rings, welded -4 JIC fittings to the ends of the steel insert and reinstalled the fittings into the cylinders. I then made a braided stainless line that ran to both JIC fittings. I bench bled the setup and it gave me very little issues when done.
Another solution would be to wrap your existing line in a heat shield material like a fire sleeve for a hydraulic hose.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #5 of 9 (permalink) Old 08-26-2009, 12:50 AM
I had one fail on me not too long ago. I took it back to my parts guy at the ford dealer and he did a one for one exchange based on the fact that the factory part failed prematurely. I believe that south bend makes an upgraded unit if you are really looking for an upgrade. Or you can just go HRT style... :)
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc singles with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes.
calebgriffin31 is offline
post #6 of 9 (permalink) Old 08-26-2009, 01:22 AM
HRT Performance
South Bend does not make an upgraded unit for the Fords - or at least they didn't not that long ago. Someone correct me if they started building them.....
2015 VW Jetta TDI
2006 VW Jetta TDI
post #7 of 9 (permalink) Old 08-28-2009, 03:11 PM Thread Starter
Ok. Thanks for the input. Do you remember the size of fittings or where you got your braided line?
Chris
post #8 of 9 (permalink) Old 08-28-2009, 10:48 PM
Some of the replacement slaves and pre-assembled hyd kits include a little thermal "diaper" that wraps around the slave cylinder. Probably just for this reason. Not sure what material it is, but fabbing something similar might help.
madpogue is offline
post #9 of 9 (permalink) Old 08-31-2009, 05:36 PM
HRT Performance
I used -4 JIC fittings and used the same 1/4" stainless braided line that I use at work
2015 VW Jetta TDI
2006 VW Jetta TDI
