Will a zf6 work in a 95 powerstroke? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 08-25-2009, 12:15 AM Thread Starter
Jjona5's Avatar
Send a message via AIM to Jjona5
I have a 5 speed 1995 powerstroke dually and im going to have to get the transmission rebuilt I believe as it grinds really badly when dropping into second. I found a used zf6 that supposedly works great and has zero problems...
Do any of you guys know if it will work on my truck? It came out of a 7.3l truck but Im wondering if the clutch and all will work.
Jjona5 is offline
post #2 of 12 (permalink) Old 08-25-2009, 12:43 AM
It wasn't me
offroadinginaz's Avatar
Re: Will a zf6 work in a 95 powerstroke?
I have heard you have to have the SD T-Case and your driveshaft lengths will be different lengths
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #3 of 12 (permalink) Old 08-25-2009, 12:47 AM
TRUBBS's Avatar
it will work, you will need a bfh or a 1inch body lift. and you need the sd t-case plus you will need to get your drive lines re-done
TRUBBS is offline
post #4 of 12 (permalink) Old 08-25-2009, 04:55 AM
What else?
smokyred's Avatar
What they said, plus a bit more. Our shop put one in an OBS several years ago, and it would be cheaper to get your zf5 rebuilt or exchanged for a rebuilt one.
Dave
smokyred is offline
post #5 of 12 (permalink) Old 08-25-2009, 03:03 PM Thread Starter
Jjona5's Avatar
Well I can get a good used zf6 for about 600 dollars with the clutch, pressure plate, and hydraulics. Where as it will cost a minimum of 950 plus tax to get my zf5 fixed... I hear the zf6 holds up a lot better to since it has an oil pump and such in it.
Jjona5 is offline
post #6 of 12 (permalink) Old 08-25-2009, 03:11 PM Thread Starter
Jjona5's Avatar
Also my truck isnt 4 wheel drive so I wont need a transfer case.
Jjona5 is offline
post #7 of 12 (permalink) Old 08-26-2009, 03:52 AM
What else?
smokyred's Avatar
Well you'll only have to get one driveshaft shortened, and move the trans crossmember back, get the zf6 wiring harness, plumb in an oil cooler, and the normal few other odds and ends.
I wouldn't say the zf6 is the more durable of the 2, but if it's what you want then I say go for it. Oh and take pics for the guys who haven't seen one.
Dave
smokyred is offline
post #8 of 12 (permalink) Old 08-26-2009, 03:56 AM Thread Starter
Jjona5's Avatar
Really? From what I read people go through syncros like crazy on the 5 speed. If that wasnt the case I would stick with the five...
Jjona5 is offline
post #9 of 12 (permalink) Old 08-26-2009, 09:37 PM
TRUBBS's Avatar
yeah i havent had much luck with the syncros on 2 of my 5 speeds but as long as you put it in rev. before you start it its not to bad. 5th grinds a lil' sometimes but owell
TRUBBS is offline
post #10 of 12 (permalink) Old 08-26-2009, 10:16 PM Thread Starter
Jjona5's Avatar
My second gear is basically impossible to use if you are moving...so I either start in second or move from first to third.
Jjona5 is offline
