Suncoast "Line Mod Valve" - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 08-24-2009, 04:33 AM Thread Starter
FordCowboy's Avatar
Since I am going to be building my transmission I was looking through suncoast's parts. They have 3 different line mod valves. The .427, .500, and .670. The .670 says for "serious HP only" so my question is can it hurt anything if I use this valve? I don't care if it shifts hard, but if it gives it too much pressure or fluid and can hurt things I won't do it.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #2 of 25 (permalink) Old 08-24-2009, 07:46 AM
OBNOXIOUS MOTORSPORTS
alterdst8's Avatar
Send a message via Yahoo to alterdst8
Re: Suncoast "Line Mod Valve"
I recently had my trans redone all suncoast parts and went with the .500 valve. It will shift Super fast and hard!! Even while driving normal with only a mildly modded motor. Cant imagine with 600+hp... can't wait I love mine! If its built right go for it, it can't hurt it. I think the .670 would be a tad to harsh though. .500's shifts plenty hard, just my .02
02 c/c lariat 4x4 DI studs, Rosewood BIG OIL, 76mm/22cm XXXH2Evil, some fuel, C2 gauges, tru trac F/R 4.30 gears, custom shafts, Stallion TC, Fully built Suncoast, mag hytech pan, 5" pipe, 25k gooseneck hidden hitch , 2 motors, STILL on pmrs in one
Mitch in Mayetta Ks my turbo sponsor
OBNOXIOUS DIESEL built build
alterdst8 is offline
post #3 of 25 (permalink) Old 08-24-2009, 08:00 AM
99 7.3's Avatar
mine has the 427, pretty decent underpower. i would almost worry about breaking stuff it is shifted any harder
09 6.7 cummins w/ a couple things
99 7.3 is offline
post #4 of 25 (permalink) Old 08-24-2009, 08:34 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
If it shifts to hard, you could turn down the shift pressure on your SCT.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #5 of 25 (permalink) Old 08-24-2009, 11:02 AM
dieselman47's Avatar
The .670 will shift HARD. If the rest of your trans is built you will have abrupt shifts. With lots of power back tires will break loose when it goes to 3rd gear.
[SIGPIC][/SIGPIC]
dieselman47 is offline
post #6 of 25 (permalink) Old 08-24-2009, 03:25 PM
Powerstroke Racer's Avatar
I have used all the above mentioned valves and went back to the .427.
You can break every hard part with a .427 if you want too.
Powerstroke Racer is offline
post #7 of 25 (permalink) Old 08-24-2009, 03:40 PM
theSLEEPER's Avatar
Dave, didn't I get a .500? Or was it the smaller one?? What valves do you usually send?
theSLEEPER is offline
post #8 of 25 (permalink) Old 08-24-2009, 04:37 PM
.427
post #9 of 25 (permalink) Old 08-24-2009, 04:38 PM
theSLEEPER's Avatar
OK. Well. It hits NICELY. But not so hard it scares me... I like it a lot!!
post #10 of 25 (permalink) Old 08-24-2009, 05:46 PM
TRX370r's Avatar
what size does the tugger kits come with?
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
