Need to upgrade trans cooler! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-21-2009, 02:07 AM Thread Starter
was wondering if a tru flo max add on will work as good as a 6.0 cooler.
i know its kinda a dead horse but i would like some advice from people with experience. of course $$ is always an issue.
dons0373 is offline
post #2 of 13 (permalink) Old 08-21-2009, 02:37 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
Re: Need to upgrade trans cooler!
Do you mean add on, as in addition to a stock 7.3 cooler?
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #3 of 13 (permalink) Old 08-21-2009, 02:44 AM
powerstrokin95stillsmokin's Avatar
i have an e40d that slips when heated up.i've heard the trans is on it's
way out.how can i check this?
95 f-450 regular cab auto trans..14ft flatbed
powerstrokin95stillsmokin is offline
post #4 of 13 (permalink) Old 08-21-2009, 03:33 AM Thread Starter
yea i guess the tru flo is put on with the stock cooler.
dons0373 is offline
post #5 of 13 (permalink) Old 08-21-2009, 04:18 AM
<-- GO BRONCOS
dblamp's Avatar
Just use the 6.0 cooler in place of the stock one.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #6 of 13 (permalink) Old 08-21-2009, 04:26 AM
Wannabe
The Tru Cool Max worked for me as an add on to the factory coolers. From what I can tell it is your choice, add the Tru Cool or replace existing with a 6.0.The reports on results seem to be about the same. The Tru Cool was VERY easy to add on though.
2001 F250 CrewCab mild mods
TxFire is offline
post #7 of 13 (permalink) Old 08-21-2009, 06:37 PM Thread Starter
another question on this topic, are the excursion and sd 6.0 coolers the same?
also do you usually see higher trans temps with tunes over stock setting?
dons0373 is offline
post #8 of 13 (permalink) Old 08-21-2009, 06:39 PM
OBS junkie
Cat_Rebel's Avatar
Anyone ever put the cooler out of a Dodge/Cummins in a Ford?
& Don's where are you located?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #9 of 13 (permalink) Old 08-21-2009, 07:15 PM
DI POWER
joediesle's Avatar
I have the Tru Max cooler, get the one rated for 40,000 gvw. 95+* and Im seeing a high of 150* trans temp. Dieselsite.com has them. I use it paralle(sp?) with the stock cooler.
01 250 sc xlt -" Forged Rods," Full Force 238/100s inj, Reg kit, Big fuel,DP F5 tunes, ATS BB turbo, ARP Headstuds, Com 910s, DI Pushrods, IDM mod, AFE Stage 2, TE2 HPOP R-IPR, BTS Trans, 6.0 intercooler, Fluidampr, HX, Cool max trans cooler, 4''exhaust & MORE.
joediesle is offline
post #10 of 13 (permalink) Old 08-22-2009, 01:56 AM Thread Starter
is that unloaded temp, how about towing?
seems like the tru cool may be an easier and cheaper option.
im in michigan so its not super hilly but i double tow with my 5er and tow often in the winter.
dons0373 is offline
