clutch replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-22-2014, 01:04 AM Thread Starter
clutch replacement
How hard of a job is it changing the clutchloride on a zf6 with 7.3. I'll be doing it on the ground. Is it possible to unbolt the cross members and slide the tranny/transfer case back enough, or just plan on dropping them?
2001 f350 eclb 4x4 k&n cold air 5" exhaust dual stacks (soon to change) bigger turbo swamp inj. Ts6 '05 lights & grill f450 ambulance springs in the rear. 4" front 3" rear lift 305/75/16 bfg at. 6 speed manual.
efilnikufesin is offline
post #2 of 3 (permalink) Old 11-22-2014, 01:07 AM Thread Starter
Re: clutch replacement
Clutch......not sure where clutchloride came fromm...lol. stupid auto correct.
post #3 of 3 (permalink) Old 11-22-2014, 02:13 AM
Freak'n know it all
gottagofast's Avatar
go to H/F and buy the big hydraulic tranny jack, jack up the truck or put it on ramps, support back of t case, remove crossmember, disconnect shafts, remove trans and t case as an assy, drop em down and then roll the jack back as far as you can.
Now get in there and pull your clutch, read my sticky in the 7.3 section and put on your new dorman bellowed up pipes (unless you already have em), then put on the new clutch n put it all back together.... as expensive as these clutches are and as easily as they can be damaged by the weight of the trans, t case not to mention the risk of injury it just isn't worth trying to cut corners.
have ur buds chip in $10 each time they borrow the jack and it'll pay for itself (IF they bring it back )
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
