slow 3-5 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 11-14-2014, 01:53 AM Thread Starter
Cool slow 3-5
Hello,ive got a 2004 with a road ripper 2000 and ive got a real slow 3-5 upshift at part throttle.occasionally it will end up in 4th and wont shift any higher until I shut it off and restart??? it is under warranty but im on the road and wont be home till thanksgiving and id like to know whats happening. Thanks!
2004 F350 dw. Barder stage 2.Warren 175/30 sticks.Driven Diesel regulated return.Sinister covered Y pipe. Road ripper 2000 trans. 5" sinister exhaust.
1428turbo is offline
post #2 of 17 (permalink) Old 11-16-2014, 11:53 PM Thread Starter
Re: slow 3-5
no body has a clue?
post #3 of 17 (permalink) Old 11-17-2014, 03:16 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: slow 3-5
What's a road ripper 2000?
Mark
Mark Kovalsky is offline
post #4 of 17 (permalink) Old 11-17-2014, 04:48 PM
stever88's Avatar
Re: slow 3-5
1997 Cargo Van 7.3 PSD, 185k miles, Stancor GPR, IH Waterpump w/ Filter, EBPV Delete.
stever88 is offline
post #5 of 17 (permalink) Old 11-18-2014, 12:24 AM Thread Starter
Re: slow 3-5
- Omaha NE
post #6 of 17 (permalink) Old 11-18-2014, 12:32 AM
matthewd11's Avatar
Re: slow 3-5
that trans is a load of crap after reading that IMO. 3/4 of what they say they do cannot be done to a torqshift due to its design.
It could be alot of things. First thing that comes to mind is tuning. What tune are you running? 'Some' delay is normal. What is 'real slow'?
matthewd11 is offline
post #7 of 17 (permalink) Old 11-18-2014, 02:18 AM Thread Starter
Re: slow 3-5
Matt Robinsons tunes.would 2 seconds be slow enough in your opinion to cause concern?
post #8 of 17 (permalink) Old 11-18-2014, 11:36 AM
matthewd11's Avatar
Re: slow 3-5
How is it at WOT? Is the delay ONLY at part throttle? Does it do it every time? Do the RPM's just 'hang' or do they go straight to redline and then eventually drop down? Yes 2 seconds is too long.
Are you sure it gets stuck in 4th at times? That gear is not used unless below 0*F.
post #9 of 17 (permalink) Old 11-19-2014, 12:41 AM Thread Starter
Re: slow 3-5
same at wot. delay is all the time. every time.goes straight to redline. scan gauge indicates 4th.temp is 30degrees.
post #10 of 17 (permalink) Old 11-19-2014, 11:59 AM
matthewd11's Avatar
Re: slow 3-5
It sounds like its slipping the direct clutch then. its toast. If you are located anywhere near the northeast and they dont warranty it for you, i build them. PM me if you're interested.
