over drive problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 12-04-2007, 03:03 AM Thread Starter
lets get smoking
Send a message via AIM to dieseltec192008
over drive problem
i have a 97 f350 and the od doesnt work in it but the thing is that it did when i got the truck but now it dont work any suggestions
dieseltec192008 is offline
post #2 of 15 (permalink) Old 12-04-2007, 06:17 AM
OBS junkie
Cat_Rebel's Avatar
Re: over drive problem
Could be a senser that went bad, or you might just need a new tranny.
Need Mark to see this one.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 15 (permalink) Old 12-04-2007, 11:09 AM Thread Starter
lets get smoking
but what sensor would it be and where would it be located
post #4 of 15 (permalink) Old 12-04-2007, 01:46 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Give me more description of what's happening. Is it the button and light on the end of the shifter doesn't work? Or is it that the trans shifts 1-2-3, but won't shift to 4th?
Mark Kovalsky is offline
post #5 of 15 (permalink) Old 12-04-2007, 04:00 PM
OBS junkie
Cat_Rebel's Avatar
Could it also be that it's going into OD but the TC isn't locking up?
RIP Will Iott
post #6 of 15 (permalink) Old 12-04-2007, 04:08 PM Thread Starter
lets get smoking
i have know idea it worked before and as i was going down a hill i droped to first gear and the steering colum had a puff of smoke from it and then the fuse blow in the fuse box. light wont come on at all for the od. replaced the fuse everything works but od.
post #7 of 15 (permalink) Old 12-04-2007, 04:19 PM
Caption This
444-4D's Avatar
Are you a diesel mechanic? I'd think anyone with an interest if fixing anything could take this info and turn it into an idea. I'd look for a bare or broken wire in the direction the smoke came from.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #8 of 15 (permalink) Old 12-04-2007, 04:26 PM Thread Starter
lets get smoking
let me be more clear there are no bear or broken wires or any burn spots on them
post #9 of 15 (permalink) Old 12-04-2007, 05:08 PM
Did you take the cover off of the steering column and inspect the wires where they enter the shifter handle? They often break right there and cause the type of problem you're having.
post #10 of 15 (permalink) Old 12-04-2007, 05:41 PM
OBS junkie
Cat_Rebel's Avatar
Has anyone put the OD off button on a seperate switch instead of on the shifter? I tend to use mine everyday while I'm in town. With 4.10 gears & 31" tires it will going into OD at 35MPH if your easy on it so I just turn it off till I get out of town. I figgure it's alot better on the tranny to stay in 3rd gear than to go into OD at the low end & keep popping in & out of OD with the flow of traffic.
RIP Will Iott
