Tranny Trouble - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 08-13-2009, 10:51 PM Thread Starter
The Fireman
big_stroker's Avatar
Tranny Trouble
Well I think that day has came. My 3 year old half way built tranny took a dump I think.
Today I was pulling out of a side street and couldnt see to well because of a big van. Pulled half way out and saw another car was coming so i went for it. I was in my economy setting. I got on it kinda hard but not really hard not WOT hard and all i heard was a BANG!!!! The RPM's when up and taked out at probably around 4 grand and then i let out and it sifted into 3rd.
Now every time i take off from a stop it will take off like normal then the rpm's will climb and it will get to about 25mph and almost 3000 rpms and finally shift into 3rd gear.
When I dont get is I can put the truck in 2nd it it will take and move alright.
Also if i through the TC lockin switch while its doing this nothing will happen. But as soon as it shifts into 3rd you can tell its locked in.
Any ideas on what may have happend or what is going on?
I really don't have the money... well i know i dont have the money right now for a BTS or anything like that.
I might just put a ZF6 in it and be done with it. I have always wanted a manual anyway I just bought an auto because its all i could find at the time.
big_stroker is offline
post #2 of 33 (permalink) Old 08-13-2009, 10:55 PM Thread Starter
The Fireman
Re: Tranny Trouble
Anyone know what I need to do in AE to be able to tell what gear the tranny is in and all that. I can log the slippage of the TC and all that but I cant find out the other stuff.
post #3 of 33 (permalink) Old 08-13-2009, 11:00 PM
matthewd11's Avatar
Re: Tranny Trouble
Is the O/D light flashing?
matthewd11 is offline
post #4 of 33 (permalink) Old 08-13-2009, 11:01 PM Thread Starter
The Fireman
Re: Tranny Trouble
Nope
Here is my AE log Tell me if there is something else I need to log also. I wasn't sure what all to log since I just got AE like a week ago.
post #5 of 33 (permalink) Old 08-13-2009, 11:11 PM
matthewd11's Avatar
Re: Tranny Trouble
Well, i'm not really sure what "exactly" the problem is, but it is definitely internal. It has to come out.
post #6 of 33 (permalink) Old 08-13-2009, 11:13 PM Thread Starter
The Fireman
Re: Tranny Trouble
Thats not what I wanted to hear
But that is what I expected
What does it hurt to drive it like this?
post #7 of 33 (permalink) Old 08-13-2009, 11:19 PM
matthewd11's Avatar
Re: Tranny Trouble
Since its going to need to be gone through, probably not much. But, me personally, i would drive it as least as possible, and as easy as possible.
When you heard the "bang", do you remember what RPM you were at? Did you cease accelerating completely?
If it was an O/D planet or a shaft, the truck shouldnt move. If it is an electrical issue, you should have a flashing O/D light. Since the "2" will work fine, but will not shift into second in "D", i dont think it is a solenoid pack.
Have you looked at the fluid?
post #8 of 33 (permalink) Old 08-13-2009, 11:27 PM Thread Starter
The Fireman
Re: Tranny Trouble
This is my DD so I have drive it. I will be easy on it thats for sure.
I'm not sure what RPM i was at. All i know is the RPM's when WAY past the red line on the truck. but i stoped accelerating completely till i heard it hit 3rd gear.
Well the truck drives fine. It will take off ok till i gets to about 15 - 25 mph and the rpms go up and then it shifts into 3rd (D)
But if i put the truck in "2" it will move and if i put it in "1" it will move.
No i haven't look at the fluid yet. I will go pull the dip stick right now and see if i see anything bad.
post #9 of 33 (permalink) Old 08-13-2009, 11:30 PM
matthewd11's Avatar
Re: Tranny Trouble
Well it definitely is a second gear issue...
Whether its hydraulic or hard parts related, you'd have to have someone else look at it first hand. Forward drum problem, or a planetary, etc...i'm not really sure.
post #10 of 33 (permalink) Old 08-13-2009, 11:32 PM Thread Starter
The Fireman
Re: Tranny Trouble
The fluid out of the dip stick looks and smells to still be good.
I will try and get a video of this but I probably wont be able to load it till morning.
