5r110 only has reverse after pca solenoid replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-22-2014, 02:51 AM Thread Starter
I just put a new pca solenoid in my 04 5r110 and I only have reverse. I cant get the lever to go past neutral. I have reverse in 123 and n but no forward at all. Some help would be greatly appreciated. Thank you
damiensdad2 is offline
post #2 of 8 (permalink) Old 10-22-2014, 02:36 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 5r110 only has reverse after pca solenoid replacement
I think the manual valve in the trans has been disconnected from the shift lever. You need to remove the pan to check this.
Mark
Mark Kovalsky is offline
post #3 of 8 (permalink) Old 10-22-2014, 03:05 PM
matthewd11's Avatar
That makes sense. Its easy to leave it disconnected while installing solenoid body. I did it once.
matthewd11 is offline
post #4 of 8 (permalink) Old 10-22-2014, 06:08 PM Thread Starter
Where is that located
post #5 of 8 (permalink) Old 10-22-2014, 06:09 PM Thread Starter
Part of the linkage in the pan?
post #6 of 8 (permalink) Old 10-23-2014, 12:02 AM Thread Starter
Ok took it all apart fixed what I could see. Now I can't shift past reverse. Me kid did shift it all the way to 1 while it was apart the first time...... Maybe that will help out
post #7 of 8 (permalink) Old 10-23-2014, 01:25 PM
I think where the linkage inside the pan connects to the valve in the solenoid body something is connected correctly.
Mark
post #8 of 8 (permalink) Old 10-24-2014, 12:31 AM Thread Starter
Sorry for all the questions but does the fluid have to be back in the trans to make the manual valve move. I took all apart the shifter moves when the valve is out of the way. When I put the solenoid body back in place the valve will not allow it to shift at all. I think I got in over my head and should have just taken it to get the pca replaced.
Thanks
