Why is my tranny overheating so easily? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 08-06-2009, 06:09 PM Thread Starter
The past few weeks ive been running into a transmission problem. It will overheat after 20 minutes of around town driving. If im on the freeway and keep the TQ locked up I could probably drive 80 miles before it reaches 230. The temp rises like normal, but keeps going to 230 and beyond if I let it. I usually try to get back home and let it cool down before it gets to 230. Is there a thermostat that isnt allowing fluid to the cooler or some kind of Bypass? Do the coolers get clogged that they no longer cool anymore? I replaced the fluid probably 30-40k miles ago, so im due for another change but dont want to change the fluid to find out its time for a rebuild.
SnwMnkys is offline
post #2 of 12 (permalink) Old 08-06-2009, 07:52 PM
BRUSKI's Avatar
Re: Why is my tranny overheating so easily?
check your pump myne just went up and it kept having problems
2004 f250::::::sold
rocking a sunburst orange jeep patriot pulling a sea doo rxp-x supercharged with stage 1 riva kit :
cheaper on fuel
BRUSKI is offline
post #3 of 12 (permalink) Old 08-06-2009, 08:58 PM Thread Starter
How do you check the pump?
SnwMnkys is offline
post #4 of 12 (permalink) Old 08-07-2009, 03:03 AM
BRUSKI's Avatar
gotta prolly take it to tranny shop... i had to, myne burnt up and melted the tq converter to the hub.
2004 f250::::::sold
cheaper on fuel
BRUSKI is offline
post #5 of 12 (permalink) Old 08-07-2009, 03:10 AM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
The transmission would have to be removed to inspect the pump visualy, but there are flow rate meters to tell if it's functioning properly, without the r/r. Most connect at the cooler line inputs.
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #6 of 12 (permalink) Old 08-08-2009, 04:32 PM
<-- GO BRONCOS
dblamp's Avatar
Need to check the bypass line.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #7 of 12 (permalink) Old 08-08-2009, 04:47 PM
Cratos's Avatar
pull the return line from the cooler to check the flow then check the incoming line I bet your cooler is clogging up you should get the same amount of fluid in 30 secondes on both sides if the return side is less ( or none at all) you need to reverse flush your cooler . if it cloggs up again time for a tranny I bet the clutches are haeded south or the converter how is it shifting??
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #8 of 12 (permalink) Old 08-10-2009, 06:13 AM Thread Starter
Shifting varies, sometimes its perfect, sometimes its really harsh, and usually when it starts to get closer to 200 the shifts are sluggish. I know its about time for a new tranny, just trying to save up.
SnwMnkys is offline
post #9 of 12 (permalink) Old 08-16-2009, 01:19 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Some transmissions have thermostats, some do not. If I knew what truck you had I could tell you.
Yes, that can happen.
Mark Kovalsky is offline
post #10 of 12 (permalink) Old 08-18-2009, 03:16 AM Thread Starter
Sorry its a 4R100. The truck is a 99 F250.
SnwMnkys is offline
