anyone tried this - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 08-06-2009, 01:10 AM Thread Starter
winkfab's Avatar
anyone tried this
has anyone tried this mod before
cOOn tranny mod - Ford Truck Enthusiasts Forums
Wink Fab - cnc machining and fabrication
2008 f250 4x4 bone stock and ready to mod/repair
97 f350 4x4 410 gears 37 BFG, 4" exhaust, dyi, tw chip,
IDM mod, .427 sonnex valve, rsk w/sd springs, grease able 4x4 lever,Rosewood stage 2, T-500 hpop,1.0 ex housing
These trucks are like crack, you just can't leave it alone.
winkfab is offline
post #2 of 19 (permalink) Old 08-08-2009, 11:55 AM
5ninef250's Avatar
Re: anyone tried this
Appears to be similar to this: http://www.sonnax.com/instructions/36948-09K-IN.pdf
1997 F250 4X4, E4OD, 12v, SDX 5x14's & DV's, benched pump, 20*, 66/71/13SS, City Diesel 6OH I/C, D60 RSK, SD Springs
1997 F350 CC 4X4, Hypermax Stage 2's, H2E, BTS pumps, BTS trans, Banks I/C
5ninef250 is offline
post #3 of 19 (permalink) Old 08-16-2009, 11:40 PM
mbg75's Avatar
anyone else have info on this mod?
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
mbg75 is offline
post #4 of 19 (permalink) Old 08-21-2009, 06:47 PM
mbg75's Avatar
Just did this mod to my truck and seems to work pretty good. firmed up the shifts nicely.
mbg75 is offline
post #5 of 19 (permalink) Old 08-23-2009, 04:54 PM Thread Starter
winkfab's Avatar
I also just finished this mod and it shifts alot better. It seems to shift a little firm in the 2-3 shiftthan the other shifts BUT I have a tw chip in it, and when I ordered it I told him I have no trans modifications to it so it may be why. I will be sending the chip back to be reflashed for some other mods aswell and will reply after it is done. I would recomend this mod.
winkfab is offline
post #6 of 19 (permalink) Old 08-26-2009, 02:58 AM
mbg75's Avatar
By far the best "free mod" i've done so far.
mbg75 is offline
post #7 of 19 (permalink) Old 09-24-2009, 01:40 PM Thread Starter
winkfab's Avatar
I originaly drilled the holes to .068 dia. When I would laying into it hard or pulling a heavy trailer I thought it shifted to hard, I was worried about the life of the trans. So I drilled and tapped the holes to fit a 8-32 thread. I drilled a .040 hole in a stainless the set screws, screwed it in with red lock-tite and pin punched the threads (its not comming out).
It shifts great now IMO. It doesn't slide into gear or snap my neck back when it shifts. Its not real hard but, it does shift into the next gear alot quicker/firmer. When I'm into the throttle or pulling its GREAT now also. So if anyone does this and youre trans slides into gear like mine DID, start by drill a .040 hole and you probly wont go bigger but if you do, only go up about .005 at a time.
winkfab is offline
post #8 of 19 (permalink) Old 09-25-2009, 01:15 PM
mbg75's Avatar
i drilled mine to 1/16" (.062) and the 1-2 shift is perfect. 2-3 is a little soft, might have to egg the hole a tiny bit to get it where i want. 3-4 can be a little firm at times under part throttle if the converter is locked.
Really can't believe not many people have tried this mod.
mbg75 is offline
post #9 of 19 (permalink) Old 09-25-2009, 02:28 PM Thread Starter
winkfab's Avatar
The more I drive it I think I should have drilled it .050 because I can barley feel it shift. When it shifts it goes into the next gear quick, I can see and hear it shift but can't really feel it. We get ice up here so I think I will leave it so It doesn't break the tires loose on the ice.
winkfab is offline
post #10 of 19 (permalink) Old 10-01-2009, 02:27 AM
So is this a reliable mod? Mine has a soft shift, esp 2-3, and the DP chip made it worse in the 80e, should this firm it up? Jody is confused, wants the chip back to check it, but the previuos owner of the chip said it shifted great. Was going to get a shift kit, but this looks like it does the same thing?
Tommy69Z28 is offline
