4r100 slipping rebuilt multiple times - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-05-2014, 06:16 PM Thread Starter
powerstrokin44's Avatar
I have a 4r100 behind my 7.3 with 250/100 and a 66 h2e. The trans is always perfect when it gets done but after about 4-5 months it starts slipping bad even when the converter is locked first 2 times the clutches were burnt and the triple disk converters went out the third time the forward drum was cracked and converter was out so I switched from a trans specialties triple to a precision triple disk. Now about six months later it's slipping again except instead of just slipping when I apply power it also chatters and does not feel like its in gear when I put it in drive but reverse feels fine. Is there a common problem that could cause all these reoccurring issues? Help please I'm tired of my truck being down twice a year! lol
2000 F-250 Stroker, Cale's tunes, modded H2E, Full Force 250/100, Built tranny from John Richmond, Precision converter, Manley rods, Mahle pistons, clevite bearings, girdle, sbi valves, a1000, Comp springs, Smith bros pushrods, billet plenums, DI RR.
powerstrokin44 is offline
post #2 of 4 (permalink) Old 10-07-2014, 03:04 AM
mech 1
Re: 4r100 slipping rebuilt multiple times
pump pressure and broken or worn valve spring in the body will cause this whic clutches were burnt the worst
7.3mud is offline
post #3 of 4 (permalink) Old 10-07-2014, 04:51 PM
Freak'n know it all
gottagofast's Avatar
Sounds to me like you have the wrong guy building ur trans.... Never hear anything like this with BTS or JW
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #4 of 4 (permalink) Old 10-07-2014, 05:17 PM
4Anna
Chuck@bdp's Avatar
Check line pressures, I would lean towards a bad pump
Chuck
