e40d mods that will support 400hp? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-02-2014, 12:37 AM Thread Starter
I don't have a budget of $3000 for a built e40d trans for my 7.3 e series so what internal components will help support the power i wanna make? I'll use the trans i have now an just build the internals an change out whatever needs to b changed unless I'm screwd an have to spend the big bucks
truckerchuck76 is offline
post #2 of 4 (permalink) Old 11-24-2014, 06:31 AM
PSD
CNDiesel's Avatar
Re: e40d mods that will support 400hp?
Spend the money$$ on a quality 3 disc converter with a billet face. I've put 1130 torque thru one built locally using basic Luk converter clutches. Cost me 750 for the converter.
Look into sonnax for their "sure cure " for the e4od. It contains a lot of updates and fixes for the trans. It's not to hard to install too once the trans is out.
Go with trans go for a shift kit. I've tried superior shift kits and the springs break in a month and give laggy shifts. Also drilling holes in the accumulator body for each up shift help out too.
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #3 of 4 (permalink) Old 12-19-2014, 06:49 PM
A good converter, valve body upgrade and a cooler. Good for 400?
1996 F250 CCSB, 4x4, auto PSD, stainless window vents.
Signature file limitations keep me from sharing more information. Follow this link to find my threads: D60 RSK install, Air vent cleaning, etc.
leojr is offline
post #4 of 4 (permalink) Old 01-23-2015, 06:37 PM
ja9788's Avatar
This is not an area you want to cheap out on...
For $1500 or so you can have a quality converter, valve body and cooler. Spend the $ now and be done with it.
The flip side is you cheap out and break internals and possibly drivetrain components then it ends up costing you a lot more than $1500.
Just my .02
< Joel >
95 F350 RCLB
+ 160/30 FFD
+ 6637
+ WW2
+ T500
+ 140v IDM Mod
+ Glowshifts...
ja9788 is offline
