Transmission temp increases really fast? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 08-02-2009, 02:28 AM Thread Starter
Stroked Smoke
tls390's Avatar
I pulled a heavier trailer for the first time today. It was around 80-85 deg. When I first took off the temps went from 140 to 210 in one gear. Once it shifted it dropped back down to around 150-160. It stayed low going down the road just went up fast on acceleration. I cannot remeber if it was in 1st or 2nd that it did it. I do have a stock tranny with a BTS valvebody and a Trucool additional cooler. Is there something wrong or something I can do to keep it lower?
2000 F-250 Crew Cab Shorty Auto 4X4 (116,000)
4" Lift 35's
EBPV delete, AIH delete, Foil delete
TS performance 6 pos (custom tunes from Rockin-S)
4" Exhaust
Ice Box intake
Tru-Cool and BTS Valvebody
Coolingmist Water
1.0 housing and turbo master
tls390 is offline
post #2 of 10 (permalink) Old 08-02-2009, 02:40 AM
Super Hauler!
Super_Hauler's Avatar
Re: Transmission temp increases really fast?
how heavy is a heavy trailer?
Super_Hauler is offline
post #3 of 10 (permalink) Old 08-02-2009, 02:49 AM Thread Starter
Stroked Smoke
tls390's Avatar
Not that heavy, but the heaviest one I will pull. Probably around 8k.
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #4 of 10 (permalink) Old 08-02-2009, 07:34 PM
tbolt's Avatar
That seems a little fast for that amount of increase. The truck in my signature with 12,000lb toy hauler won,t do that with wot takeoffs in 40T
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #5 of 10 (permalink) Old 08-02-2009, 07:48 PM Thread Starter
Stroked Smoke
tls390's Avatar
That is what I thought. I had a hard time getting it to shift so the temp would drop without it getting over 220.
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #6 of 10 (permalink) Old 08-04-2009, 12:56 AM Thread Starter
Stroked Smoke
tls390's Avatar
I did some reading and found out that the gauge probe should be in the tranny on the drivers side by the linkage. I looked and there is nothing there. After looking some more the previous owner has a fitting in the line going to the coolers. Could this be the problem?
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #7 of 10 (permalink) Old 08-04-2009, 01:02 AM Thread Starter
Stroked Smoke
tls390's Avatar
To clarify the previous post, the fitting is the temp sender.
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #8 of 10 (permalink) Old 08-04-2009, 01:21 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
It's normal for temps to rise that fast in the line to the cooler. Get on a long, slow grade and you'll see 300F in that line!
Mark Kovalsky is offline
post #9 of 10 (permalink) Old 08-04-2009, 03:35 AM Thread Starter
Stroked Smoke
tls390's Avatar
Thanks for the help. I think I will install a new gauge in the port on the drivers side so I have some good comparisons.
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #10 of 10 (permalink) Old 08-04-2009, 03:38 AM
tbolt's Avatar
I think you will see its ok after you move the sender.
Glen
tbolt is offline
