Anyone know any thing about Transgo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 08-01-2009, 12:03 AM Thread Starter
Talked with the local tranny shop today about installing either a BTS or JW valve body, but they recommended going with a Transgo "reprogramming kit" kit number 4R100 HD2 Tugger. They said that they have been installing these kits, and the previous model, in F550 field sprayer trucks for a long time and they have been holding up great. They claim that the trannys are now lasting 4-5 years instead of 1 year for a stocker.
Has anyone ever used this kit? Any pros/cons?
Thanks
Paul
FYI, the truck is going to be use about 60% of the time towing a gooseneck or 5th wheel camper, both usually weigh around 14,000lbs.
PHS79 is offline
post #2 of 12 (permalink) Old 08-01-2009, 12:06 AM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Re: Anyone know any thing about Transgo?
Ive used the trans go tugger kits many times now and love usung them. But I see better shifting with a custom made valve body that matches your tuner.
The trans go kit would be a cheap alternative option to a VB.
SMOK'N BLUE STROKER is offline
post #3 of 12 (permalink) Old 08-01-2009, 12:22 AM
Don't EFN worry about it
Aljay's Avatar
My bud put sonnax parts in mine just another alternative .
Tuned by T Wildman
Aljay is offline
post #4 of 12 (permalink) Old 08-01-2009, 12:32 AM
Powerstroke Racer's Avatar
Thanks
Paul
Just about all the high HP builders use that kit in their builds.
Powerstroke Racer is offline
post #5 of 12 (permalink) Old 08-01-2009, 01:00 AM
04stroker's Avatar
How hard is it to install a transgo shift kit? ive never dealt with them
04stroker is offline
post #6 of 12 (permalink) Old 08-01-2009, 01:29 AM
Aljay's Avatar
Well to put it in terms I can do it so you can too.Pretty simple follow the directions.
Tuned by T Wildman
Aljay is offline
post #7 of 12 (permalink) Old 08-01-2009, 07:26 PM
aggie's Avatar
The tugger kit is a pretty elaborate shift kit. Like David said most of the builders use it in one form or fashion, and i beleive BTS Brian helped develop a lot of the parts they use, but dont quote me on that. I would contact one of the hi-po tranny builders though and have them set you up with what you need, as different poewr levels, different uses of the truck dictate different setups on the pressures etc.
[SIGPIC][/SIGPIC]
aggie is offline
post #8 of 12 (permalink) Old 08-28-2009, 04:36 AM
Does the tugger kit firm up all the shifts ?
fastmust88 is offline
post #9 of 12 (permalink) Old 08-28-2009, 05:11 AM
strokin baby!!!!!!!!
broncof250444's Avatar
Yes it will firm up all of the shifts.
I love my Trans Go kit, no problems out of it and it does slam the gears in i have my holes drilled to the max, so when i stand on it in 2wd it will normally lite the tires up threw 2nd gear and bark 3rd gear and that with 35" tires.
2012 F350 CCSB Larait 4x4
MBRP 5", DPF and egr delete with H&S mini max!
500 rwhp/1200 ft tq
8.5 1/8 mile
13.3 1/4 mile
broncof250444 is offline
post #10 of 12 (permalink) Old 08-28-2009, 05:16 AM
Crazy Redneck
UNCOOL's Avatar
Its a good kit.
I put one in when I did my conversion untill the BTS full build next year.
The hardest part is getting the pump halfs lined up correctly when you bolt them back together.
I drilled .083 holes I think and the shifts are positive and not hard.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
