4r100 issue? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-21-2014, 03:30 PM Thread Starter
4r100 issue?
I have a 99 7.3 with 280k miles. While driving hwy speeds around 70 it felt like the tranny tried to downshift and then banged back into od. truck basically bucked for a second or two. no lights flashing and no other problems. drove just fine after.should i be concerned? thanks in advance
ndagenais is offline
post #2 of 4 (permalink) Old 10-07-2014, 03:14 AM
mech 1
Re: 4r100 issue?
how old is the fluid could be foaming a little if its old
7.3mud is offline
post #3 of 4 (permalink) Old 03-04-2015, 06:38 PM Thread Starter
Re: 4r100 issue?
so i figured out the problem. sorry for the daly. apparently on an exact spot of interstate in front of a trucking company with a large tower antenna. my truck does this. it seems to be electrical interference as it actually will raise the engine rpms. it wont buck and try to change gears if i am completely off the gas pedal. it is the craziest thing and it is consisitent at the exact spot it will start and stop acting up. wish i knew how to fix it. any helps or thoughts appreciated.
post #4 of 4 (permalink) Old 03-04-2015, 06:39 PM Thread Starter
Re: 4r100 issue?
i dont believe it is trans related at all except the trans is getting crazy mixed signals from the engine as this interference makes the engine surge.
