South bend release fork - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-30-2009, 11:05 PM Thread Starter
Is there a big difference in the stock unit vs an upgraded South bend release fork? Thanks guys!
On Edit, this is for a '99 with a Midwest Transmission '05+ ZF6 in it...
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc singles with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes.
calebgriffin31 is offline
post #2 of 5 (permalink) Old 07-31-2009, 12:57 AM
throttle jockey by trade
hookin78's Avatar
Re: South bend release fork
The south bend , I believe , is just the newer factory upgrade, and yes you have a '99, They have been known to be weak. I don't remeber where but somewhere. I put the newer factory one in mine when I installed my south bend dual disc. It was cheap.
2000 F-350 six speed
2000 F-350 automatic (custom tree dent mod)
1978 F-350 4speed 460 pulling truck
hookin78 is offline
post #3 of 5 (permalink) Old 07-31-2009, 01:06 AM Thread Starter
I will get a picture of it here shortly, but I pretty much bent it in half. So the new upgraded stock unit will do me just fine?
post #4 of 5 (permalink) Old 07-31-2009, 01:13 AM
hookin78's Avatar
Yep, as long as everything else in your clutch set-up is good.
hookin78 is offline
post #5 of 5 (permalink) Old 07-31-2009, 03:28 AM
Yea, I talked to peter the other day, The upgrade is the newer factory one, and side by side there is a big difference. I snapped my orig almost in half. Hopefully the "upgrade" will last.
99.5 cc lwb drw lariat, 6 speed. Intake, exhaust, 38r, tunes..
2001 psdxcab xlt 6speed 4x4. afeII pg7, mbrp 4", DP-Tf5,SBC 12cb 3600# DD, 18x9moto's on 35's ,.... some other stuff
1982 vw syncro 5speed 4x4, suby 2.2L air lockers, 30"tsl's:
1968 barracuda formula S
chrisreedtn is offline
