Bell housings on Gas/Diesel 5sps the same? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-30-2009, 02:22 AM Thread Starter
What about the gear ratios? Anyone know what they are? Will they swap?
ScubaCat is offline
post #2 of 4 (permalink) Old 07-30-2009, 02:30 AM
all ur OBS r belong to me
OldschoolPSD's Avatar
Send a message via MSN to OldschoolPSD
Re: Bell housings on Gas/Diesel 5sps the same?
More info please?
some of the 7.3 IDI truck came with an adapter plate between the motor and trans to adapt the trans from BBF to IH bolt pattern. Since then, the diesels have been their own bolt pattern
The ZF5 gas and diesel transmissions are different ratios. The gasser trans is rated at 425ft/lbs and the diesel at 475ft/lbs.
anything past 1997 I have no clue about
Ford stopped building trucks in 1997
OldschoolPSD is offline
post #3 of 4 (permalink) Old 07-30-2009, 12:00 PM Thread Starter
My bad, I spaced out big time I guess....
This is for an 07 4x4 SD Wondering if there is any differance between the 5sp auto's they use...
ScubaCat is offline
post #4 of 4 (permalink) Old 07-31-2009, 02:37 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The 5 speed auto for a 6.8L and 6.0L are essentially identical. There is one minor difference that I know of, but either will work in either application. All TorqShifts have the same bellhousing and the same gear ratios.
Mark Kovalsky is offline
