Transmission People, your advice pls! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-09-2014, 11:08 PM Thread Starter
Hi guys,
So my 6.0 went under the knife a couple months ago for the typical upgrades like studs, ported manifolds, exhaust, exhaust manifolds, etc. Based on what I have read, I should be in the neighborhood of 425-450 ish hp and 750 or more torque at max power. Won't be getting a bigger turbo or larger sticks.
The stock converter is rated at 750 torque so I was going to upgrade it... but the one manufacturer that is close by told be their trans shop will probably not grant me a warrenty on the thing cuz it's going in a used transmission. The truck currently sits at 250 XXX kms/150 XXX miles.
I heard these transmissions are pretty tough. Then it go me thinking. I bought this truck second hand and I am unaware of it's service history. When I bought it, I got the trans fluid tested and it was definiately overdue (obvisously got it flushed at the dealership). The trans is a big unknown it would seem cuz the problems (if any) are not well documented unlike the 6.0 engine.
I haven't had a problem with it. Shifts fine. Don't do a lot of hauling. Typicallly not my daily driver. Weather is typically moderate where I live. On the rare occasion, when I place it in "D" and hit the throttle, it might take a couple second to respond. Other than that, it seems fine.
I don't care so much about the warrenty (most of the time, they don't come in handy) as I am concerned with anything I should be doing or paying attention to. Should I just get the converter replaced and be done with it? What do you guys think?
Thanks
HankyD is offline
post #2 of 5 (permalink) Old 09-10-2014, 12:00 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Transmission People, your advice pls!
Who rates it at that torque level? Ford certainly didn't.
I don't understand why you are replacing the converter. What's wrong with it?
Mark
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 09-10-2014, 01:41 AM Thread Starter
I have read on this forum that the stock converter is rated right around that point. I don't know if "rated" is the right word to use but you get the idea; it is what some members believe the stock unit can handle, perhaps based on first hand experience.
Some time ago, I posted in the technical info section of this forum regarding the stock torque converter and the mods I was going to do in the future. In that post, it was suggested that an upgraded torque converter was a good idea. The member who suggested the upgrade had his stock converter burn out.
Anyway that's beside the point. I don't know a great deal about transmissions and I just want mine to be reliable with this additionally power so if there is any recommendations, it would be appreciated.
HankyD is offline
post #4 of 5 (permalink) Old 09-13-2014, 06:41 PM
Drive it like it is. If you have any issues or extra money rebuild the trans with a little better parts and a triple disc converter. It's not a good idea to put a big expensive converter in front of a used trans. If there is a problem with the trans and it comes apart it will take the converter with it.
Lipka101 is offline
post #5 of 5 (permalink) Old 09-17-2014, 01:29 AM
I agree. I had a 2005 6.0 that dyno-ed @ 500/ 1000 rear wheel. Bought truck new, very good service by me. After going through the motor, I put a Go-Go DD solenoid and it performed flawlessly with 139K miles on it...until I rolled it on icey roads. Yes, I'm still sore about that one.
TomS is offline
