trans cooler, oil cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-27-2009, 11:56 PM Thread Starter
DieselPower1966's Avatar
Send a message via MSN to DieselPower1966
I'm going to order a hd trans cooler, will it hook up using the existing lines?
what size are the oem lines?
also, can I use a trans cooler as an engine oil cooler? the reason for this is price, on Jegs an oil cooler is more than $100 over the cost of a trans cooler,
if I can do this, I think I'd be using their oil adapter kit?
any help out there?
thanks
John
DieselPower1966
John
DieselPower1966 is offline
post #2 of 3 (permalink) Old 08-02-2009, 10:27 PM
<-- GO BRONCOS
dblamp's Avatar
Re: trans cooler, oil cooler
What type of HD tranny cooler?
SD stock hard lines are 3/8"
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #3 of 3 (permalink) Old 08-04-2009, 03:41 AM
tbolt's Avatar
Why do you need an additional oil cooler? In your local I can't see you having an issue. My stock setup does fine here in the extreem heat of Az. pulling miles of up to 6% grades. Just curious.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
