trans temp question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-27-2009, 09:34 PM Thread Starter
DieselPower1966's Avatar
Send a message via MSN to DieselPower1966
trans temp question
it was 90 here today, I was cruising on the hiway doing 75, and my trans temp said 170-175 my truck was not loaded, and no trailer, should I be concerned?
what is the max temp a tranny can run at? it is stock, but still plan on putting in a John Woods Valve body. should I add a larger trans cooler?
will the valve body help with the temps?
rpms were at 2300, boost at 6-7 lbs fuel pressure at 61 lbs, 4:10 gearing
I'm not sure if all that matters, but what the hell,,,
thanks John
DieselPower1966
John
DieselPower1966 is offline
post #2 of 11 (permalink) Old 07-27-2009, 09:48 PM
Moved in
sagebel's Avatar
Re: trans temp question
That sounds about right. After I went to the 6.0 trans cooler I am seeing no more than 155 lightly loaded. Haven't gone heavy with the new cooler yet.
If you don't ever see temps over 200 I would put the money towards a different mod unless you find a good deal.
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #3 of 11 (permalink) Old 07-28-2009, 12:56 AM
tbolt's Avatar
No need to worry till about 220 or so. With the situation you described in 115* mine will run 170-180. When towing a 12,000lb toyhauler it will creep up to about 200 or so. I have a stock cooler and a JWvalve body.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #4 of 11 (permalink) Old 07-28-2009, 01:08 AM
Your fine, if you still concerned you can get a trans cooler.
KingDiesel is offline
post #5 of 11 (permalink) Old 07-28-2009, 01:43 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Anywhere from 60-100F above ambient is normal.
Mark Kovalsky is offline
post #6 of 11 (permalink) Old 07-28-2009, 03:31 AM
tbolt's Avatar
Yes and that makes it tough here. It was 114 yesterday and 113 at 1:30 this afternoon. When pulling a 12,000lb trailer on 6% for 8-9 miles things will warm up but 220 won't hurt it for a few min. 240-250 I would be concerned and change the fluid soon. My neighbor hit 250 for about 15 min with his allison. Got home and it smelled BAD. we changed it and it's ok. Don't know how he got it that hot, his 1st gen Dmax don't have a huge amount of power.
Glen
tbolt is offline
post #7 of 11 (permalink) Old 07-28-2009, 06:57 PM Thread Starter
thanks all for replying, I was a little concerned but not any more.
DieselPower1966
John
post #8 of 11 (permalink) Old 07-28-2009, 08:47 PM
220 won't hurt it for a very long time. Ford allows up to 220 indefinitely. They allow up to 250 for no more than 1/2 hour.
post #9 of 11 (permalink) Old 07-31-2009, 08:16 AM
Big Mike
british columbia's Avatar
Wow i tow a 8000 lb toy hauler and rarely ever see 200 degrees, even towing uphill on a 100 degrees+ day . Regular driving sees around 170- 175 degees on a hot day . It reads 165 degees on a cool day
2008 F350 Harley-Davidson ed. PSD
2.5 Inch Pro -Comp Front leveling Springs
british columbia is offline
post #10 of 11 (permalink) Old 07-31-2009, 10:08 PM
Caption This
444-4D's Avatar
You have a Torque Shift transmission. Those have a better cooling system than a 4r100.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
